Re: Custom builder in Papyrus-based RCP won't run [message #1834032 is a reply to message #1833973] |
Fri, 30 October 2020 14:22 |
Hi Oliver,
it is strange if your builder is not launch excepted if you removed the Eclipse builder from your RCP (I don't know if it is possible or not, I never made RCP...)
If I remember well, I noticed that it required to make a change in a project to launch the build process.
Concerning your two questions:
1. We are not sure this patch will be released in 2012-20 (and at this time, we don't plan to provide an extension way allowing user to add their own builder/validator).
The purpose of this developpement was to provide a way for us (papyrus developper) to get error marker during the build process. We need errors on EMF/Uml models (like you), but also in Manifest.MF and in others ecore model/metamodel used by Papyrus internally.
2. The Papyrus nightly is the most stable as possible, but if you read frequently this forum, you maybe saw that we planne to make a Papyrus 5.0 for 2020-12 with bigs changes. mainly, the remove of re-exported dependencies in the plugin + migration to java 11.
These patches should be integrated in few weeks. Once it will be pushed, you will need to update your code on this new version of Papyrus (if your developpement targets 2020-12 too).
Concerning the UML models/diagrams created by users, there should be no impact for them.
FUDForum. Page generated in 0.02820 seconds
