Home » Modeling » TMF (Xtext) » xtend code(writing xtend code)
xtend code [message #1833775] Fri, 23 October 2020 16:23 Go to next message
Muhammad Salman Tayyab is currently offline Muhammad Salman TayyabFriend
Member
Hey, I have written the Java code and the grammar also. Now, I am facing difficulty in writing the xtend code. I am attaching everything please have a look and help. Thanks in advance.
Grammar
Model:
parts+=ModelPart*;
ModelPart:
Video | Videouse;
Video:
"video_list" "{" videos+=Videodef* "}";
Videodef:
name=ID "=" value=STRING ";";
Videouse:
"actions" "{" playvideo+=Videoshow* "}";
Videoshow:
"show(" vid=[Videodef] ");";
Java Code
import java.util.Scanner;
public class grammarcode {
// TODO Auto-generated method stub
Scanner input=new Scanner(System.in);
String[] videos= new String[2];
// String[] actions;
System.out.println("Please enter the videos name to play");
for(int i=0;i<(videos.length);i++) {
videos[i]=input.nextLine();
System.out.println("video_list{");
System.out.println(videos[i] +";");
System.out.println("}");
System.out.println("actions{");
for(int i=0;i<(videos.length);i++){
System.out.println("show("+ videos[i]+ ");");
[Updated on: Fri, 23 October 2020 16:24]
Report message to a moderator
Re: xtend code [message #1833776 is a reply to message #1833775] Fri, 23 October 2020 16:25 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
HI, what is your question
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: xtend code [message #1833778 is a reply to message #1833776] Fri, 23 October 2020 17:11 Go to previous messageGo to next message
Member
Can you convert my Java code into the xtend code which I can write in the mydslGenerator.xtend file. So that after running the mydslGenerator.xtend file java code will be generated?
Please see the attachment.
  • Attachment: xtend.PNG
    (Size: 34.50KB, Downloaded 31 times)
Re: xtend code [message #1833779 is a reply to message #1833778] Fri, 23 October 2020 17:15 Go to previous messageGo to next message
I still don't under stand
Given which model file
Which java file should be generated
You java file does not mention
Video and Video use instances at all
Re: xtend code [message #1833781 is a reply to message #1833779] Fri, 23 October 2020 17:29 Go to previous messageGo to next message
Member
This is my Grammar:
grammar org.video1.example.mydsl.MyDsl with org.eclipse.xtext.common.Terminals
generate myDsl "http://www.video1.org/example/mydsl/MyDsl"
Model:
parts+=ModelPart*;
ModelPart:
Video | Videouse;
Video:
Videodef:
Videouse:
Videoshow:
That how my grammar will look when it is tested
video_list{
video1="C://new_folder/video/move_hand.mp4";
video2="C://new_folder/video/make_sound.mp3";
actions{
show(video1);
show(video2);
Now from the grammar I want to generate the java code
I am also attaching the screenshots of my grammar file, tested grammar file, and both the other screenshot where I tried to write the code( named logic file) so that java code will be generated and its output what I get.
Re: xtend code [message #1833782 is a reply to message #1833781] Fri, 23 October 2020 17:34 Go to previous messageGo to next message
yes but given
			video_list {
				oneVideo = "This is a vid";
				twoVideo = "This is the second vid";
				anotherVid = "This is another vid";
			actions {
				show(oneVideo);
				show(anotherVid);
which code should be generated
Re: xtend code [message #1833783 is a reply to message #1833782] Fri, 23 October 2020 17:35 Go to previous messageGo to next message
Member
video_list {
actions {
show(oneVideo);
show(anotherVid);
The above code will be generated.
Salman
Re: xtend code [message #1833784 is a reply to message #1833783] Fri, 23 October 2020 17:39 Go to previous messageGo to next message
i still dont see the java code you want to generate.
i just see
- grammar
- sample model
- some generator code
but what is the code given the sample model you want to output
e.g.
package org.xtext.example.mydsl5.generator;
public class videodecl {
		System.out.println("There is the video \"This is a vid\" with name oneVideo");
		System.out.println("There is the video \"This is the second vid\" with name twoVideo");
		System.out.println("There is the video \"This is another vid\" with name anotherVid");
		System.out.println("playing oneVideo");
		System.out.println("playing anotherVid");
[Updated on: Fri, 23 October 2020 17:50]
Re: xtend code [message #1833785 is a reply to message #1833784] Fri, 23 October 2020 18:02 Go to previous messageGo to next message
Member
Below java code I want to generate
Salman
Re: xtend code [message #1833786 is a reply to message #1833785] Fri, 23 October 2020 18:14 Go to previous messageGo to next message
Member
I hope that you understand what I am trying to achieve.
Salman
Re: xtend code [message #1833787 is a reply to message #1833786] Fri, 23 October 2020 18:19 Go to previous messageGo to next message
in the code you want to generate there is no
oneVideo , twoVideo
there is no "This is another vid"
and there is no play anotherVid
so how does your code relate to the model
and how does it change if you delete
from the model
Re: xtend code [message #1833788 is a reply to message #1833787] Fri, 23 October 2020 18:27 Go to previous messageGo to next message
Member
Now, If you understand the scenario please update my code and you can clearly see in my code, first I am taking input from the user and I am also attaching a screenshot of my code output.
I write the code in a simple java environment and not in the xtend environment.Through xtend I want to generate java code.
I am newbie that's why I don't know how to write the logic in .xtend file.
  • Attachment: output.PNG
    (Size: 9.80KB, Downloaded 32 times)
[Updated on: Fri, 23 October 2020 18:27]
Re: xtend code [message #1833789 is a reply to message #1833788] Fri, 23 October 2020 18:37 Go to previous messageGo to next message
i still dont understand.
you show a java app and a use interacts with it
how does this relate to xtext generator.
if you use this
	override void doGenerate(Resource resource, IFileSystemAccess2 fsa, IGeneratorContext context) {
		fsa.generateFile('greetings.txt', '''
the generator will generate your java code
Re: xtend code [message #1833790 is a reply to message #1833789] Fri, 23 October 2020 18:46 Go to previous messageGo to next message
Member
I just show you the java app for understanding and also write java code for my own understanding. This code has nothing to do with the generator.
I think you still not understand my point.
Can you please write a code in the mydslgenerator.xtend file according to my grammar and the tested grammar? So that I can understand.
Right now, I am facing difficulty in the syntax of the xtend.
Salman
Re: xtend code [message #1833791 is a reply to message #1833790] Fri, 23 October 2020 18:49 Go to previous messageGo to next message
i said: i can do if you tell me the java code which you want to generate for this model
			video_list {
			actions {
				show(oneVideo);
				show(anotherVid);
i am asking you:
how shall the generated java code for this model file look like
is wrong.
so which code should be generated instead?
Re: xtend code [message #1833792 is a reply to message #1833791] Fri, 23 October 2020 18:53 Go to previous messageGo to next message
Member
First of all, thank you for your time.
Just to be simple. Please write the code which gives the output like this model below.
video_list {
actions {
show(oneVideo);
show(anotherVid);
Salman
Re: xtend code [message #1833793 is a reply to message #1833792] Fri, 23 October 2020 19:14 Go to previous messageGo to next message
Member
Still not understand?
Salman
Re: xtend code [message #1833794 is a reply to message #1833793] Fri, 23 October 2020 19:55 Go to previous messageGo to next message
Member
generated code will be like this:
video_list{
video1="Any path";
video2="Any path";
action{
show(video1) ;
show(video2);
Now, you will understand.
Salman
Re: xtend code [message #1833795 is a reply to message #1833794] Fri, 23 October 2020 20:10 Go to previous message
that is easy
		for (m : resource.allContents.toIterable.filter(Model)) {
			fsa.generateFile("video/videodecl.txt", '''
			video_list{
			«FOR v : m.parts.filter(Video)»
				«FOR vd : v.videos»
					name="«Strings.convertToJavaString(vd.value)»";
				«ENDFOR»
			«ENDFOR»
			action{
			«FOR u : m.parts.filter(Videouse)»
				«FOR play : u.playvideo»
					show(«play.vid.name»);
				«ENDFOR»
			«ENDFOR»
but this aint java code that is generated
[Updated on: Fri, 23 October 2020 20:11]
Previous Topic:Performance issue in QueuedBuildData
Next Topic:Adding generated objects to the index
Current Time: Wed Aug 17 10:35:19 GMT 2022
Powered by FUDForum. Page generated in 0.03480 seconds
