Home » Modeling » TMF (Xtext) » refresh dependecies before importing the project on eclipse(Follow weird steps while trying to import project on Eclipse)
refresh dependecies before importing the project on eclipse [message #1833538] Fri, 16 October 2020 09:48 Go to next message
Luca Reccia is currently offline Luca RecciaFriend
Hi guys, I've a simple Xtext that works just fine on my machine.
However, whenever I try to import it on a new pc I should always:
1. clone from the repo
2. perform `gradle build --refresh-dependecies`
3. import the project in Eclipse DSL
4. restore the .classpath file which gets overwritten by Eclipse
Correct .classpath that makes the project work
<classpath>
	<classpathentry kind="src" path="src"/>
	<classpathentry kind="src" path="src-gen"/>
	<classpathentry kind="src" path="xtend-gen"/>
	<classpathentry kind="con" path="org.eclipse.jdt.launching.JRE_CONTAINER/org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType/JavaSE-11"/>
	<classpathentry kind="con" path="org.eclipse.pde.core.requiredPlugins"/>
	<classpathentry kind="output" path="target/classes"/>
</classpath>
Wrong .classpath overwritten by Eclipse while importing the project
<classpath>
	<classpathentry kind="src" output="bin/main" path="src">
		<attributes>
			<attribute name="gradle_scope" value="main"/>
			<attribute name="gradle_used_by_scope" value="main,test"/>
		</attributes>
	</classpathentry>
	<classpathentry kind="src" output="bin/main" path="xtend-gen">
		<attributes>
		</attributes>
	</classpathentry>
	<classpathentry kind="con" path="org.eclipse.jdt.launching.JRE_CONTAINER/org.eclipse.jdt.internal.debug.ui.launcher.StandardVMType/JavaSE-11/"/>
	<classpathentry kind="con" path="org.eclipse.buildship.core.gradleclasspathcontainer"/>
	<classpathentry kind="output" path="bin/default"/>
</classpath>
I've discovered this steps via a lot of trial and error but now I would like to finally fix the project (being able to avoid steps 2 and 3 while installing it somewhere)
I've searched online, but, not knowing much of gradle or maven, I didn't get that far. I was wondering if any of you as any idea on what is happening inside my codebase.
Thank you for your help.
[Updated on: Fri, 16 October 2020 09:48]
Report message to a moderator
Re: refresh dependecies before importing the project on eclipse [message #1833541 is a reply to message #1833538] Fri, 16 October 2020 09:52 Go to previous message
Christian Dietrich is currently offline Christian DietrichFriend
there is no both
either eclipse
or gradle
in your case the gradle eclipse integration does update the .classpath files to be gradle way.
see also https://docs.gradle.org/current/userguide/eclipse_plugin.html#sec:eclipse_customizing_the_generated_files
Twitter : @chrdietrich
[Updated on: Fri, 16 October 2020 09:58]
Previous Topic:Path Expression Issue
Next Topic:Performance issue in QueuedBuildData
Current Time: Fri Apr 19 04:21:13 GMT 2024
Powered by FUDForum. Page generated in 0.01622 seconds
