Setting base_url at runtime. [message #1833442] |
Tue, 13 October 2020 11:04 |
Makarand Kurkute Messages: 2 Registered: October 2020 |
I am using BIRT viewer in our application, Tomcat path like is like \webapps\<MyApp>\webcontent\birt
BIRT report viewer is working fine on local PC using URL like http://localhost:8080/<MyApp>/frameset..
We deployed it on server with SSL enable environment (https://<InstanceName>/<MyApp>) . when we execute the BIRT report somehow viewer redirect to the http://localhost:8080
To fix this we have added base_url in viewer.properties as follow.
base_URL = "https://<InstanceName>/<MyApp>"
Now issue is we have multiple instances on same server and base_URL setting should be different for each instances the we creates.
Is it any way to set the base_URL at runtime?
[Updated on: Wed, 14 October 2020 09:24] Report message to a moderator
FUDForum. Page generated in 0.03309 seconds
