Home » Archived » BIRT » Date parameter not working Date=any date(Unable to set Date parameter as Date= Oct 1, 2019)
Date parameter not working Date=any date [message #1833036] Thu, 01 October 2020 08:01 Go to next message
Muhammad Minhal is currently offline Muhammad MinhalFriend
Hi All,
I am using Birt 4.3.1 I have to pass my date parameter as date should be equal to a specific date. The date range parameter(Start Date/End Date) is working fine but I want to add the parameter like date = Oct 1, 2019
My birt is connected with DB2 maximo database.
Following is the sample Code that I am trying:
if(params["Date"].value)
params["where"]+= " and table.date = " + MXReportSqlFormat.getTimestampFunction(params["Date"]);
When I try to put date like this it does not show any data while date range parameter is working fine.
[Updated on: Thu, 01 October 2020 09:44]
Report message to a moderator
Re: Date parameter not working Date=any date [message #1833667 is a reply to message #1833036] Tue, 20 October 2020 19:28 Go to previous message
rbaak Mising name is currently offline rbaak Mising nameFriend
Member
Its been a little while since I used Maximo but I think you want to have something like this:
var yourdt = Formatter.format( params["Date"].value, "MM/dd/yy");
//here you are adding on to your base sql statement
sqlText = sqlText + "" and table.date =yourdt "
[Updated on: Tue, 20 October 2020 22:53]
Previous Topic:X-Axis Interactivity
Next Topic:onCreate error
Current Time: Fri Dec 09 07:18:08 GMT 2022
Powered by FUDForum. Page generated in 0.02384 seconds
