Home » Polarsys » Capella workbench » Image as a Note(Can I add an image as a Note?)
Image as a Note [message #1833004] Wed, 30 September 2020 13:26 Go to next message
Luc Baldwin is currently offline Luc BaldwinFriend
I would like to know if there is a way to add an image as a note to a diagram.
Is it possible? If so, how can I do it?
Re: Image as a Note [message #1833013 is a reply to message #1833004] Wed, 30 September 2020 15:13 Go to previous messageGo to next message
Samuel Rochet is currently offline Samuel RochetFriend
Hi Luc,
No, you can't add an image as a note to a diagram.
However, you can use images in the diagram description or customize elements' appearance using an image.
Re: Image as a Note [message #1833017 is a reply to message #1833013] Wed, 30 September 2020 16:36 Go to previous messageGo to next message
Stephane LACRAMPE is currently offline Stephane LACRAMPEFriend
You may use a constraint to do it.
Stephane LACRAMPE
Obeo Canada
Re: Image as a Note [message #1833033 is a reply to message #1833017] Thu, 01 October 2020 07:25 Go to previous message
Ok, thank you very much for your replies
Previous Topic:Anomalies when using GIT-CAPELLA coupling (merge tool)
Next Topic:Search for diagams with broken elements
Current Time: Tue Dec 03 05:41:33 GMT 2024
Powered by FUDForum. Page generated in 0.04122 seconds
