Home » Newcomers » Newcomers » View Terminal, after upgrade to Eclipse 2020-09, is broken(The view terminal seem to be broken after an upgrade to Eclipse 2020-09)
View Terminal, after upgrade to Eclipse 2020-09, is broken [message #1832961] Wed, 30 September 2020 06:52 Go to next message
Emmanuel DUMAS is currently offline Emmanuel DUMASFriend
I use Eclipse, base install CDT/C and extension for XML, and PyDev.
I use sometime view Terminal (Window > Show View > Others , search and Terminal). After start of view, usually, I push on button "Open a terminal" , valid a pop-up and then I have a terminal.
Few weeks ago, I accept upgrade to Eclispse v 2020-09, Windows > Check for update , configure with https://download.eclipse.org/releases/latest .
Since this upgrade, on view Terminal, push on button "Open a terminal" has no effect.
How repair this ?
I can give you more information.
Best regard
Emmanuel
Re: View Terminal, after upgrade to Eclipse 2020-09, is broken [message #1832975 is a reply to message #1832961] Wed, 30 September 2020 09:00 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
Which TM Terminal Connector Extensions features do you have installed?
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: View Terminal, after upgrade to Eclipse 2020-09, is broken [message #1832987 is a reply to message #1832975] Wed, 30 September 2020 12:13 Go to previous messageGo to next message
Nitin Dahyabhai wrote on Wed, 30 September 2020 09:00
TM Terminal 10.0.0.202008310002 org.eclipse.tm.terminal.feature.feature.group Eclipse CDT
TM Terminal Local Connector Extensions 10.0.0.202008310315 org.eclipse.tm.terminal.connector.local.feature.feature.group Eclipse CDT
TM Terminal SSH Connector Extensions 10.0.0.202008310315 org.eclipse.tm.terminal.connector.ssh.feature.feature.group Eclipse CDT
TM Terminal Telnet Connector Extensions 10.0.0.202008310315 org.eclipse.tm.terminal.connector.telnet.feature.feature.group Eclipse CDT
TM Terminal Serial Connector Extensions 10.0.0.202008310315 org.eclipse.tm.terminal.connector.cdtserial.feature.feature.group Eclipse CDT
Is-it answer that you expect ?
Re: View Terminal, after upgrade to Eclipse 2020-09, is broken [message #1833000 is a reply to message #1832987] Wed, 30 September 2020 13:07 Go to previous messageGo to next message
Yes, unfortunately having some of those installed means their absence isn't the cause of your problems.
Nitin Dahyabhai
Re: View Terminal, after upgrade to Eclipse 2020-09, is broken [message #1833470 is a reply to message #1833000] Wed, 14 October 2020 07:18 Go to previous message
I have reinstall every thing from 0. Now Eclispe run as I want, with an operational view terminal.
Previous Topic:Eclipse 2020-09 fails to find plug-in sources on Linux
Next Topic:Installer Error
Current Time: Sat Feb 27 23:20:41 GMT 2021
Powered by FUDForum. Page generated in 0.03183 seconds
