How To Use The Element Based Edge Creation Tool [message #1832944] |
Tue, 29 September 2020 12:57  |
I have defined an element based edge that I can define from the tree editor that displays in my model just fine but when I try to create it from my creation tool it doesn't work. The link isn't created between the elements that I select.
I have the tool defined as such:
Begin > Change Context var:source > Create Instance Model::eClass > Set 'tgt', var:target
I don't know what I am doing wrong here, since this is an element based edge that I have defined in my metamodel I assumed that I would need to create and instance and still access the target and source variables in order to set them. I haven't been able to find any tutorial about using the creation tool for element based edges and previous forum posts haven't been clear about the steps required for defining the creation tool from start to end.
FUDForum. Page generated in 0.12761 seconds
