Home » Modeling » TMF (Xtext) » Xtext document set content does not update the model immediately(Xtext model update)
Xtext document set content does not update the model immediately [message #1832672] Wed, 23 September 2020 08:45 Go to next message
Georgiana Ecobici is currently offline Georgiana EcobiciFriend
It is possible to trigger the update of the model after getDocument().set(content)?
The model seems to be updated later, not after updating the document content.
Re: Xtext document set content does not update the model immediately [message #1832675 is a reply to message #1832672] Wed, 23 September 2020 09:04 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
how do you access the model?
maybe you can call a readOnly on the xtextDocument
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: Xtext document set content does not update the model immediately [message #1832682 is a reply to message #1832675] Wed, 23 September 2020 09:54 Go to previous messageGo to next message
I access the model like this:
XtextResource resource = provider.getResource();
EList<EObject> content = resource.getContents();
domainModel = (Model) resource.getContents().get(0);
I called document.readOnly like below, I haven't added any code in the process method and now it seems to work:
document.readOnly(new IUnitOfWork.Void<XtextResource>() {
public void process(XtextResource state) throws Exception {
Thanks!
Re: Xtext document set content does not update the model immediately [message #1832683 is a reply to message #1832682] Wed, 23 September 2020 09:58 Go to previous message
btw the propery way would be to do the read operation in that work
Previous Topic:Open call hierarchy option
Next Topic:Help with labeling features
Current Time: Wed Mar 03 12:10:01 GMT 2021
Powered by FUDForum. Page generated in 0.02067 seconds
