I can't open java codes [message #1832629] |
Tue, 22 September 2020 10:39 |
Berke Sayan Messages: 3 Registered: September 2020 |
ı have four different exception and ı can't open my codes. I write under this write and I seperate with -----------. I didn't find solution.
eclipse.buildId=4.17.0.I20200902-1800
java.version=14.0.2
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=tr_TR
Framework arguments: -product org.eclipse.epp.package.java.product -product org.eclipse.epp.package.java.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.java.product -data file:/C:/Users/Berke/eclipse-workspace/ -product org.eclipse.epp.package.java.product
org.eclipse.e4.ui.workbench
Error
Tue Sep 22 13:27:59 TRT 2020
Exception occurred while unrendering: org.eclipse.e4.ui.compatibility.editor=org.eclipse.e4.ui.model.application.ui.basic.impl.PartImpl@2c34fb51 (tags: [Editor, removeOnHide, org.eclipse.wb.core.guiEditor], contributorURI: null) (widget: null, renderer: null, toBeRendered: false, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (contributionURI: bundleclass://org.eclipse.ui.workbench/org.eclipse.ui.internal.e4.compatibility.CompatibilityEditor, object: null, context: null, variables: [], label: null, iconURI: null, tooltip: null, dirty: false, closeable: true, description: null)
org.eclipse.e4.core.di.InjectionException: java.lang.NullPointerException
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:68)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:999)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:964)
at org.eclipse.e4.core.internal.di.InjectorImpl.disposed(InjectorImpl.java:456)
at org.eclipse.e4.core.internal.di.Requestor.disposed(Requestor.java:160)
at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier$ContextInjectionListener.update(ContextObjectSupplier.java:83)
at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.update(TrackableComputationExt.java:105)
at org.eclipse.e4.core.internal.contexts.TrackableComputationExt.handleInvalid(TrackableComputationExt.java:68)
at org.eclipse.e4.core.internal.contexts.EclipseContext.dispose(EclipseContext.java:186)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.clearContext(PartRenderingEngine.java:990)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeRemoveGui(PartRenderingEngine.java:963)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$1(PartRenderingEngine.java:870)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:865)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:45)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.removeGui(PartRenderingEngine.java:849)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.subscribeTopicToBeRendered(PartRenderingEngine.java:185)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:564)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:58)
at org.eclipse.e4.core.di.internal.extensions.EventObjectSupplier$DIEventHandler.handleEvent(EventObjectSupplier.java:92)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:205)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:203)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:234)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:151)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:132)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:75)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:44)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:55)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:63)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:424)
at org.eclipse.e4.ui.model.application.ui.impl.UIElementImpl.setToBeRendered(UIElementImpl.java:314)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.hidePart(PartServiceImpl.java:1402)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.hidePart(PartServiceImpl.java:1332)
at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.closePart(StackRenderer.java:1182)
at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.access$0(StackRenderer.java:1168)
at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer$3.close(StackRenderer.java:1042)
at org.eclipse.swt.custom.CTabFolder.onMouse(CTabFolder.java:1958)
at org.eclipse.swt.custom.CTabFolder.lambda$0(CTabFolder.java:335)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:89)
at org.eclipse.swt.widgets.Display.sendEvent(Display.java:4195)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1037)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4012)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3612)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$5.run(PartRenderingEngine.java:1157)
at org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:338)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1046)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:155)
at org.eclipse.ui.internal.Workbench.lambda$3(Workbench.java:644)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:551)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:153)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:150)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:401)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:657)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:594)
at org.eclipse.equinox.launcher.Main.run(Main.java:1465)
at org.eclipse.ui.internal.PopupMenuExtender.dispose(PopupMenuExtender.java:512)
at org.eclipse.ui.internal.PartSite.dispose(PartSite.java:308)
at org.eclipse.ui.internal.EditorSite.dispose(EditorSite.java:141)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.disposeSite(CompatibilityPart.java:439)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityEditor.disposeSite(CompatibilityEditor.java:140)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.internalDisposeSite(CompatibilityPart.java:430)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.invalidate(CompatibilityPart.java:268)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.destroy(CompatibilityPart.java:417)
... 66 more
java.version=14.0.2
org.eclipse.e4.ui.workbench.swt
Error
Problems occurred when invoking code from plug-in: "org.eclipse.e4.ui.workbench.swt".
... 66 more
java.version=14.0.2
Error
Tue Sep 22 13:27:56 TRT 2020
Unable to create class 'org.eclipse.ui.internal.e4.compatibility.CompatibilityEditor' from bundle '369'
org.eclipse.e4.core.di.InjectionException: java.lang.NoClassDefFoundError: org/eclipse/jface/util/Assert
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:416)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:332)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:202)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:91)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:60)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:42)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:132)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:999)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:659)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:765)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$0(PartRenderingEngine.java:736)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:730)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:714)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.lambda$0(PartServiceImpl.java:104)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.lambda$0(UIEventHandler.java:38)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:236)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:133)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4725)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:219)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:38)
at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElementGen(ElementContainerImpl.java:170)
at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:188)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.showElementInWindow(ModelServiceImpl.java:659)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.bringToTop(ModelServiceImpl.java:623)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.delegateBringToTop(PartServiceImpl.java:786)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.bringToTop(PartServiceImpl.java:400)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.showPart(PartServiceImpl.java:1262)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:3197)
at org.eclipse.ui.internal.WorkbenchPage.lambda$9(WorkbenchPage.java:3102)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:74)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3100)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3070)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3061)
at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:376)
at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:182)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:285)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:251)
at org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchRun(SelectionDispatchAction.java:274)
at org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(SelectionDispatchAction.java:252)
at org.eclipse.jdt.internal.ui.packageview.PackageExplorerActionGroup.handleOpen(PackageExplorerActionGroup.java:366)
at org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$3.open(PackageExplorerPart.java:546)
at org.eclipse.ui.OpenAndLinkWithEditorHelper$InternalListener.open(OpenAndLinkWithEditorHelper.java:48)
at org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredViewer.java:802)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:174)
at org.eclipse.jface.viewers.StructuredViewer.fireOpen(StructuredViewer.java:799)
at org.eclipse.jface.viewers.StructuredViewer.handleOpen(StructuredViewer.java:1118)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrategy.java:275)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.java:270)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:310)
Caused by: java.lang.NoClassDefFoundError: org/eclipse/jface/util/Assert
at org.eclipse.wb.gef.core.EditPart.addChild(EditPart.java:509)
at org.eclipse.wb.internal.gef.graphical.RootEditPart.setContent(RootEditPart.java:131)
at org.eclipse.wb.internal.gef.core.AbstractEditPartViewer.setInput(AbstractEditPartViewer.java:134)
at org.eclipse.wb.internal.core.editor.ViewersComposite.bindViewers(ViewersComposite.java:92)
at org.eclipse.wb.internal.core.editor.DesignComposite.createViewersComposite(DesignComposite.java:147)
at org.eclipse.wb.internal.core.editor.DesignComposite.createGEFComposite(DesignComposite.java:128)
at org.eclipse.wb.internal.core.editor.DesignComposite.createEditorComposite(DesignComposite.java:112)
at org.eclipse.wb.internal.core.editor.DesignComposite.createMainComposite(DesignComposite.java:94)
at org.eclipse.wb.internal.core.editor.DesignComposite.<init>(DesignComposite.java:69)
at org.eclipse.wb.internal.core.editor.JavaDesignComposite.<init>(JavaDesignComposite.java:53)
at org.eclipse.wb.internal.core.editor.DesignPage.createControl_pageBook(DesignPage.java:186)
at org.eclipse.wb.internal.core.editor.DesignPage.createControl(DesignPage.java:172)
at org.eclipse.wb.internal.core.editor.multi.DefaultMultiMode.createTab(DefaultMultiMode.java:100)
at org.eclipse.wb.internal.core.editor.multi.MultiPagesMode.create(MultiPagesMode.java:90)
at org.eclipse.wb.internal.core.editor.multi.DesignerEditor.createPartControl(DesignerEditor.java:87)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPartControl(CompatibilityPart.java:154)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityEditor.createPartControl(CompatibilityEditor.java:96)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:361)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalInject(InjectorImpl.java:140)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:405)
... 87 more
Caused by: java.lang.ClassNotFoundException: org.eclipse.jface.util.Assert cannot be found by org.eclipse.wb.core_1.10.0.201812270937
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:516)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:171)
at java.base/java.lang.ClassLoader.loadClass(ClassLoader.java:522)
... 114 more
java.version=14.0.2
org.eclipse.jface
Error
Tue Sep 22 13:38:11 TRT 2020
Problems occurred when invoking code from plug-in: "org.eclipse.jface".
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.internalFixContext(PartServiceImpl.java:448)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.bringToTop(PartServiceImpl.java:409)
FUDForum. Page generated in 0.08401 seconds
