Re: ClassNotFoundException on run [message #1832614 is a reply to message #1832591] |
Tue, 22 September 2020 07:27 |
Hi Heinrich,
It very much should indeed. From the trace I assume you are using the 2020-06 release (4.8.0) ? can you see if the included jar do contain any of the mentioned classes (I just checked in the released jars and it is indeed there) ?
Are you importing/depending on the associated packages or is the common plugin correctly loaded when the RCP starts ?
/Quentin
Re: ClassNotFoundException on run [message #1832621 is a reply to message #1832614] |
Tue, 22 September 2020 07:59 |
Bernhard Heinrich Messages: 2 Registered: September 2020 |
Quentin Le Menez wrote on Tue, 22 September 2020 07:27Hi Heinrich,
/Quentin
Hey and thank you for your replies,
Yes, I'm using the 2020-06 release, after updating from 2020-03 to see if the exceptions are fixed. The included jar does indeed contain the mentioned classes.
I'm new to the project and Eclipse RCP, so I'm not exactly sure what you mean, but the plugin is included in the run configuration.
Bernhard
[Updated on: Tue, 22 September 2020 08:00] Report message to a moderator
FUDForum. Page generated in 0.03976 seconds
