Home » Modeling » TMF (Xtext) » Post process transient attributes from comments
Post process transient attributes from comments [message #1832467] Fri, 18 September 2020 12:42 Go to next message
Yannick DAVELUY is currently offline Yannick DAVELUYFriend
Here is an example of what I want to achieve :
test.myDsl:
 * description of cls
 * @author yan
class cls
In the corresponding Ecore model, the EClass of class defines 2 transients attributes : description and author.
When the text file is parsed I would like to populate the description (" description of cls") and author("yan") of the class EObject from the comment.
On the other side, when the EMF objects are serialized (e.g if edited in ecore editor), I would like to associate the comment from the description and author attributes.
How can I do this ?
Yannick
Re: Post process transient attributes from comments [message #1832468 is a reply to message #1832467] Fri, 18 September 2020 12:45 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
please have a look at IDerivedStateComputer
http://xtextcasts.org/episodes/18-model-optimization
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: Post process transient attributes from comments [message #1832469 is a reply to message #1832468] Fri, 18 September 2020 13:04 Go to previous messageGo to next message
Thanks, it seems perfect for parsing phase.
I implement this part first then I will have a look on how to override the comments during the serialization phase.
Yannick
Re: Post process transient attributes from comments [message #1832565 is a reply to message #1832469] Mon, 21 September 2020 08:18 Go to previous messageGo to next message
The IDerivedStateComputer works fine for retrieving the derived attributes from the documentation extracted with MultiLineCommentDocumentationProvider.
Now, how can I serialize a custom comment for an EObject ?
Yannick
Re: Post process transient attributes from comments [message #1832568 is a reply to message #1832565] Mon, 21 September 2020 08:28 Go to previous messageGo to next message
no idea, you have to digg into serializer
Re: Post process transient attributes from comments [message #1832593 is a reply to message #1832568] Mon, 21 September 2020 13:54 Go to previous messageGo to next message
The Xtext design provides first class modeling of the model but relegates whitespace and comments to Node model magic from which the serializer can rescue whatever you want by a customized HiddenTokenSequencer. org.eclipse.ocl.xtext.base.serializer.BaseHiddenTokenSequencer might give you some ideas.
Ed Willink
Re: Post process transient attributes from comments [message #1832598 is a reply to message #1832593] Mon, 21 September 2020 14:52 Go to previous message
Hi Ed,
Thanks for your reply.
I'me working on a workaround by using a custom non hidden MY_ML_COMMENT terminal rules.
The grammar and the processing of derived attributes (parsing+serialization) are ok. On the UI side, I lost all the default behaviour with default documention, syntax highlighting of comments, code folding,...
I will have a look to the HiddenTokenSequencer.
I can't find the org.eclipse.ocl.xtext.base.serializer.BaseHiddenTokenSequencer class. Where is it defined ?
Yannick
Previous Topic:Problems with installing Xtext from update site
Next Topic:EObjectDescription userData and information from other Resources
Current Time: Thu Mar 04 01:01:10 GMT 2021
Powered by FUDForum. Page generated in 0.02570 seconds
