how do I edit toolchains? [message #1832424] |
Thu, 17 September 2020 11:22  |
I've tried to set up a custom toolchain and got confused.
What I can edit under Preferences > Core Build Toolchains does not seem to match with the available options at Project-Properties > C/C++ Build > Tool Chain Editor.
I'm sure that I'm just missing something obvious here. I remember Project-Properties > C/C++ Build > Settings used to have a tab named toolchain. That was perfect and is exactly what I need now. I just want to select a path and the binaries for the tools.
You probably just have to point me in the right direction. I've done the same thing on other IDEs and (much) older versions of eclipse tons of times.
Eclipse IDE for C/C++ Developers
Version: 2020-03 (4.15.0)
Build id: 20200313-1211
[Updated on: Thu, 17 September 2020 11:23] by Moderator
FUDForum. Page generated in 0.03756 seconds
