Home » Newcomers » Newcomers » I am facing trouble in opening Eclipse(An error has occurred. See the log file C:\Program Files\Java\Eclipse\configuration\1600324509194.log)
I am facing trouble in opening Eclipse [message #1832360] Thu, 17 September 2020 06:51 Go to next message
Nithi Daniel is currently offline Nithi DanielFriend
!SESSION 2020-09-17 12:05:07.864 -----------------------------------------------
eclipse.buildId=M20120914-1800
java.version=14.0.2
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments: -product org.eclipse.epp.package.jee.product
Command-line arguments: -os win32 -ws win32 -arch x86_64 -product org.eclipse.epp.package.jee.product
!ENTRY org.eclipse.equinox.simpleconfigurator 4 0 2020-09-17 12:05:11.685
!MESSAGE FrameworkEvent ERROR
!STACK 0
org.osgi.framework.BundleException: The bundle "org.eclipse.equinox.simpleconfigurator_1.0.301.v20120828-033635 [1]" could not be resolved. Reason: Missing Constraint: Bundle-RequiredExecutionEnvironment: CDC-1.1/Foundation-1.1,J2SE-1.4
at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolverError(AbstractBundle.java:1332)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolutionFailureException(AbstractBundle.java:1316)
at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:323)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:390)
at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1176)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:559)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:544)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:457)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:243)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:438)
at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:340)
!ENTRY org.eclipse.osgi 4 0 2020-09-17 12:05:11.715
!MESSAGE Bundle initial@reference:file:plugins/org.eclipse.equinox.simpleconfigurator_1.0.301.v20120828-033635.jar was not resolved.
!ENTRY org.eclipse.osgi 2 0 2020-09-17 12:05:11.742
!MESSAGE One or more bundles are not resolved because the following root constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2020-09-17 12:05:11.743
!SUBENTRY 2 org.eclipse.equinox.simpleconfigurator 2 0 2020-09-17 12:05:11.743
!MESSAGE Missing required capability Require-Capability: osgi.ee; filter="(|(&(osgi.ee=CDC/Foundation)(version=1.1))(&(osgi.ee=JavaSE)(version=1.4)))".
!ENTRY org.eclipse.osgi 2 0 2020-09-17 12:05:11.748
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2020-09-17 12:05:11.748
!MESSAGE Bundle org.eclipse.equinox.simpleconfigurator_1.0.301.v20120828-033635 [1] was not resolved.
!SUBENTRY 2 org.eclipse.equinox.simpleconfigurator 2 0 2020-09-17 12:05:11.748
!ENTRY org.eclipse.osgi 4 0 2020-09-17 12:05:11.765
!MESSAGE Application error
!STACK 1
java.lang.IllegalStateException: Unable to acquire application service. Ensure that the org.eclipse.core.runtime bundle is resolved and started (see config.ini).
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:74)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at java.base/jdk.internal.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at java.base/jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.base/java.lang.reflect.Method.invoke(Method.java:564)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
Can anyone guide me what to do?
Re: I am facing trouble in opening Eclipse [message #1832366 is a reply to message #1832360] Thu, 17 September 2020 08:08 Go to previous message
The build ID M20120914 suggests this is an 8 year old version of Eclipse. That will not work running on Java 14.
It would be better to use something new:
Ed Merks
Previous Topic:eclipse打不开
Next Topic:Modify build.properties - tycho package plugin
Current Time: Sun Feb 28 14:02:35 GMT 2021
Powered by FUDForum. Page generated in 0.05397 seconds
