Home » Modeling » M2T (model-to-text transformation) » Acceleo build(Showing error when I write in generate.mtl file)
Acceleo build [message #1832123] Wed, 09 September 2020 13:56 Go to next message
Rubia Anjum is currently offline Rubia AnjumFriend
Errors occurred during the build.
Errors running builder 'Acceleo Builder' on project 'org.eclipse.acceleo.module.sample'.
org.eclipse.emf.ecore.xmi.UnresolvedReferenceException: Unresolved reference '/0/gen'. (platform:/resource/org.eclipse.acceleo.module.sample/bin/org/eclipse/acceleo/module/sample/main/generate.emtl, 293, 57)
Why this error occur and what's the solution for this?
[Updated on: Wed, 09 September 2020 13:57]
Report message to a moderator
Re: Acceleo build [message #1832148 is a reply to message #1832123] Thu, 10 September 2020 07:42 Go to previous messageGo to next message
Given your limited description, I can only say that you did something wrong wrt the tool's expectations.
If you read https://wiki.eclipse.org/OCL/ForumNetiquette you may get some tips that avoid the need for long ping pong rallies.
If you read the forum you will find many users who have problems like yours, some are idiot user, some are idiot tool. Without details it is hard to tell which category your problem falls in to.
Ed Willink
Re: Acceleo build [message #1832157 is a reply to message #1832148] Thu, 10 September 2020 12:14 Go to previous messageGo to next message
[comment encoding = UTF-8 /]
[module generate('http://www.eclipse.org/uml2/5.0.0/UML')]
[template public generateElement(c : Class)]
	[file (c.classFileName(), false, 'UTF-8')]
	package [c.containingPackages().name->sep('.')/];
	//[protected ('imports')]
	//[/protected]
	 public class [c.name.toUpperFirst()/] {
		[for (p: Property | c.attribute) separator('\n')]
	     private [p.type.name/] [p.name/];
	   	[/for]
	     public [p.type.name/] get[p.name.toUpperFirst()/]() {
	       return this.[p.name/];
	   	[/for]
		[for (o: Operation | c.ownedOperation) separator('\n')]
	     public [o.type.name/] [o.name/]() {
	       	//[protected (o.name)]
			// TODO should be implemented
			//[/protected]
	   	[/for]
	[/file]
[comment if/]
[/template]
Anything written outside this template cause error
[query public classFileName (c:Class):String =
c.qualifiedName().replaceAll('\\.','/').concat('.java')
This is the code I'm writing in generate.mtl file using "acceleo perspective". I'm facing that problem while I write anything outside [template] whether it's [query] or other [template].
The error it shows is below
Re: Acceleo build [message #1832158 is a reply to message #1832157] Thu, 10 September 2020 12:15 Go to previous messageGo to next message
No Message Body
[Updated on: Thu, 10 September 2020 12:17]
Re: Acceleo build [message #1832163 is a reply to message #1832158] Thu, 10 September 2020 13:43 Go to previous message
I see no zipped project so I have no idea how you configured tings.
I see http://www.eclipse.org/uml2/5.0.0/UML for which the usual answer is READ THE COMMENTS in the generated main program or the numerous iterations of this same question on this forum.
Ed Willink
Previous Topic:How to read model of any metamodel in Acceleo?
Next Topic:Yet another enquiry on Maven builds
Current Time: Thu Mar 04 04:31:15 GMT 2021
Powered by FUDForum. Page generated in 0.01901 seconds
