Re: Git clone/pull with SSH from Azure DevOps repositories fails frequently [message #1832952 is a reply to message #1832911] |
Tue, 29 September 2020 21:42 |
Thomas Wolf Messages: 576 Registered: August 2016 |
Unfortunately getting a log from Eclipse with these Apache MINA sshd messages is indeed hard. With JGit, it should be possible in the way I wrote above, but if you can't reproduce with JGit, that won't help.
With Eclipse, you have to figure out which logging back-end, if any, is installed. My normal "Eclipse for Committers" apparently has none; so to get logging output I have to download one, for instance org.slf4j.impl.log4j12, and then copy that into my Eclipse's "dropins" folder. Then write a log4j configuration and pass that via a Java system property defined via the _JAVA_OPTIONS environment variable to Eclipse.
Here's a way to get DEBUG logging for Apache MINA sshd from the Eclipse for Java Developers package that you appear to be using. That one includes a logback logging back-end (via m2e), so write a config for logback:
<configuration scan="true" scanPeriod="5 seconds">
<appender name="STDOUT" class="ch.qos.logback.core.ConsoleAppender">
<encoder>
<pattern>%d{HH:mm:ss.SSS} [%thread] %-5level %logger{40} - %msg%n</pattern>
</encoder>
</appender>
<logger name="org.apache.sshd" level="DEBUG" additivity="false">
<appender-ref ref="STDOUT" />
</logger>
<root level="WARN">
</root>
</configuration>
Save it as file "logback-debug.xml" somewhere.
Then set the environment variable and start Eclipse from the command line. Then pull from your repo on Azure DevOps. You should get a lot of DEBUG logging in the terminal.
On my OS X machine, I just start
$ _JAVA_OPTIONS='-Dlogback.configurationFile=file:///absolute/path/to/logback-debug.xml' ./eclipse &
With some luck, such a log will perhaps show something that can give me a clue as to what might be going on.
FUDForum. Page generated in 0.04350 seconds
