Home » Newcomers » Newcomers » Eclipse update error due to snap read-only system
Eclipse update error due to snap read-only system [message #1831892] Tue, 01 September 2020 21:43 Go to next message
Mohammad Mahdi Amirian is currently offline Mohammad Mahdi AmirianFriend
I tried to update eclipse in ubuntu 20.04 LTS, but was stopped by this error:
'Update Software' has encountered a problem. An error occurred while uninstalling
The detail is as follows:
session context was:(profile=epp.package.java, phase=org.eclipse.equinox.internal.p2.engine.phases.Uninstall, operand=[R]org.eclipse.rcp_root 4.14.0.v20191210-0610 --> null, action=org.eclipse.equinox.internal.p2.touchpoint.natives.actions.CleanupzipAction).
Backup of file /snap/eclipse/48/readme/readme_eclipse.html failed.
File that was copied to backup could not be deleted: /snap/eclipse/48/readme/readme_eclipse.html
I guess it is due to the snap read-only system as I cannot remove the mentioned file manually. Running eclipse as root and updating also causes the same error obviously because the file cannot also be removed with the root permission.
Re: Eclipse update error due to snap read-only system [message #1831914 is a reply to message #1831892] Wed, 02 September 2020 14:24 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
You'll need to talk to whomever created this snap package.
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: Eclipse update error due to snap read-only system [message #1832709 is a reply to message #1831892] Wed, 23 September 2020 16:51 Go to previous messageGo to next message
Rajat Dhanotiya is currently offline Rajat DhanotiyaFriend
Have you got any solution to this problem? I am also getting error exactly same as yours while upgrading eclipse version to 2020-09. if you have found any solution please share.
Thank you
Re: Eclipse update error due to snap read-only system [message #1832710 is a reply to message #1832709] Wed, 23 September 2020 17:12 Go to previous messageGo to next message
Not yet, any solution would be appreciated.
Re: Eclipse update error due to snap read-only system [message #1832726 is a reply to message #1832710] Wed, 23 September 2020 20:58 Go to previous messageGo to next message
Are snap packages intended to be upgraded in ways other than picking up a newer version of the snap?
Nitin Dahyabhai
Re: Eclipse update error due to snap read-only system [message #1832731 is a reply to message #1832726] Thu, 24 September 2020 02:32 Go to previous messageGo to next message
I really don't know what snap is and how it is upgraded. I haven't upgraded that manually. I use Ubuntu LTS and it is upgraded by the system (if it is!)
Re: Eclipse update error due to snap read-only system [message #1832735 is a reply to message #1832731] Thu, 24 September 2020 04:36 Go to previous message
also I am not able to edit eclipse.ini file to increase heap size, how can I modify this file as root?
Previous Topic:Can't launch Eclipse after installing it on Ubuntu
Next Topic:eclipse would not launch
Current Time: Sun Apr 11 05:26:53 GMT 2021
Powered by FUDForum. Page generated in 0.03736 seconds
