Home » Eclipse Projects » Sirius » Set selected value via button press.
Set selected value via button press. [message #1831773] Fri, 28 August 2020 15:41 Go to next message
Max Jordan is currently offline Max JordanFriend
I currently have a popup window that has a container with 2 lists, a text box and a button inside it.
The lists display what I want, but I want to be able to update the value to whatever's inside the text box on a button press.
How would I go about this.
Re: Set selected value via button press. [message #1831993 is a reply to message #1831773] Fri, 04 September 2020 09:58 Go to previous message
Laurent Fasani is currently offline Laurent FasaniFriend
Hello
You have mutilple way in Sirius to display a windows including creating your own dialog in an service called in your tools.
Could you precise how you displayed your windows?
regards
Laurent Fasani - Obeo
Previous Topic:Refreshing project dependencies programmatically
Next Topic:Programmatically create instances
Current Time: Tue Apr 16 10:37:38 GMT 2024
Powered by FUDForum. Page generated in 0.10013 seconds
