Home » Language IDEs » C / C++ IDE (CDT) » newbie help on compile error(compile error)
newbie help on compile error [message #1831693] Wed, 26 August 2020 17:49 Go to next message
alan smith is currently offline alan smithFriend
i am very new to eclipse (only started using it yesterday), installation went ok, everything seems to be working apart from i cant compile my code, i get the following error and don't know where to start to fix it
make: *** No rule to make target '../../points', needed by 'project/points'. Stop.
i am using eclipse 2020-06 on a linux machine with the arduino plugins from the marketplace
not sure if i need to have the arduino IDE installed or not.
any help would be appreciated
thanks
Re: newbie help on compile error [message #1832342 is a reply to message #1831693] Wed, 16 September 2020 17:28 Go to previous messageGo to next message
pourpc monish is currently offline pourpc monishFriend
Hey, may there is a problem with your code or you might not have defined the target, kindly check it once and try again lowes life but you may not need the arduino IDE as far as i believe. Let's see how things work if IDE too, planning to get it from market place in a couple of days.
Re: newbie help on compile error [message #1832355 is a reply to message #1832342] Thu, 17 September 2020 05:52 Go to previous messageGo to next message
David VavraFriend
The message from make, make: *** No rule to make target ...
means the makefile doesn't have the named target OR there is no makefile.
Rather than guessing, why don't you tell us specifically what you've done?
That is, what actions preceded getting this message?
Wouldn't hurt to also provide the exact content of the build log vs an abbreviated one.
Re: newbie help on compile error [message #1832633 is a reply to message #1832355] Tue, 22 September 2020 12:01 Go to previous message
Mark Smith is currently offline Mark SmithFriend
Member
See this articles
https://www.eclipse.org/downloads/packages/installer
Previous Topic:generating risc-v machine code from c/c++ files
Next Topic:how do I edit toolchains?
Current Time: Fri Nov 01 22:52:22 GMT 2024
Powered by FUDForum. Page generated in 0.03207 seconds
