Home » Modeling » TMF (Xtext) » Bundle activator on xtext
Bundle activator on xtext [message #1831374] Tue, 18 August 2020 13:16 Go to next message
Patrick Catillaz is currently offline Patrick CatillazFriend
I have an Xtext project and try to allow simple java functions to extend the language by external user.
The goal is to allow the users to add custom functions
To do that I do the following :
1) I create an eclipse plugin with statics functions.
When I generate the jar a small annotation processor will build me an XML file.
Currently my jar must contain a dummy class that implement IStartup. (+
2) In my xtext project, I create a listener that activate the plugin created in step one and register all available functions.
It's work fine when I was only in Eclipse. But when I try to run with maven, I didn't found a way to activate my bundle.
Do you know how to do it?
Thanks in advance
Re: Bundle activator on xtext [message #1831375 is a reply to message #1831374] Tue, 18 August 2020 13:25 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
in standalone mode there is usually no osgi. Xtext offten solves these problems then via java ServiceLoader
see e.g.ResourceServiceProviderServiceLoader
i would assume you would have to come up with something similar
Need professional support for Xtext, Xpand, EMF?
Go to: https://www.itemis.com/en/it-services/methods-and-tools/xtext
Twitter : @chrdietrich
Re: Bundle activator on xtext [message #1831378 is a reply to message #1831375] Tue, 18 August 2020 15:14 Go to previous messageGo to next message
By run with Maven I presume you just mean run standalone for which it is essential that you invoke the XXXStandaloneSetup.doSetup() that Xtext kindly generates for you.
Ed Willink
Re: Bundle activator on xtext [message #1831400 is a reply to message #1831378] Wed, 19 August 2020 05:47 Go to previous messageGo to next message
Thanks, I will try with ServiceLoader
Ed Willink wrote on Tue, 18 August 2020 15:14
Ed Willink
Yes, following the message of Christian it's what I will try. My only assumption is the need to create needed files to use ServiceLoader (this jar will be made by business user and try to keep it simple.
Re: Bundle activator on xtext [message #1831401 is a reply to message #1831400] Wed, 19 August 2020 06:02 Go to previous message
yes you need information in jar for service loaders.
maybe you can also try to use classgraph to search the classpath
Previous Topic:Cross-referencing challenges
Next Topic:Not able to open project files when xtext build runs
Current Time: Wed Mar 03 00:33:59 GMT 2021
Powered by FUDForum. Page generated in 0.02131 seconds
