Home » Language IDEs » Java Development Tools (JDT) » java.lang.NoSuchMethodError in JDT Core runtime(This problem rises when using locally built JDT Core )
java.lang.NoSuchMethodError in JDT Core runtime [message #1831294] Mon, 17 August 2020 00:11 Go to next message
Malinda Dilhara is currently offline Malinda DilharaFriend
Hello everyone,
I'm feeling like I've gotten way out of my depth here and need some guidance.
I have a very basic question but due to the lack of experience in eclipse developments, this a very hard to figure out alone.
What I am trying to do
Perform a small modification to `eclipse.jdt.core`, rebuilt, and use the locally built jar in my research project.
What steps I have taken so far
1. Created an eclipse workspace as described in Link
2. Built eclipse.jdt.core using the mvn -P build-individual-bundles package
3. Added the resulting jar file (`org.eclipse.jdt.core-3.23.0-SNAPSHOT.jar`) which is created in the target folder to my project as a maven dependency.
Problem
Even though my project successfully compiled with the modified jar file, it gives me the following run time error.
Exception in thread "pool-2-thread-1" java.lang.NoSuchMethodError: org.eclipse.core.runtime.SubMonitor.split(I)Lorg/eclipse/core/runtime/SubMonitor;
	at org.eclipse.jdt.core.dom.ASTParser.createAST(ASTParser.java:820)
	at utils.JavaASTUtil.parseSource(JavaASTUtil.java:87)
	at change.CFile.<init>(CFile.java:32)
	at change.RevisionAnalyzer.buildGitModifiedFiles(RevisionAnalyzer.java:310)
	at change.RevisionAnalyzer.analyzeGit(RevisionAnalyzer.java:130)
	at change.ChangeAnalyzer.analyzeGit(ChangeAnalyzer.java:243)
	at change.ChangeAnalyzer.analyzeGit(ChangeAnalyzer.java:228)
	at main.MainChangeAnalyzer$2.run(MainChangeAnalyzer.java:99)
	at java.base/java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1128)
	at java.base/java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:628)
	at java.base/java.lang.Thread.run(Thread.java:834)
Additional steps
1. When I use the eclipse.jdt.core library in the maven central repository it works perfectly fine. It suggests that the problem is with the locally built jar.
2. I had to use Java 11 when configuring the eclipse workspace. Therefore, I changed Java version of my project to 11.
Questions
Is there any configuration or any setting that I need to use in eclipse core runtime when using locally built jar?
Any idea to Investigate this error is much appreciated.
pom.xml of my project is as below.
[img]http://[/img]<project xmlns="http://maven.apache.org/POM/4.0.0" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
    xsi:schemaLocation="http://maven.apache.org/POM/4.0.0 http://maven.apache.org/xsd/maven-4.0.0.xsd">
    <modelVersion>4.0.0</modelVersion>
    <groupId>AtomicASTChangeMining</groupId>
    <artifactId>AtomicASTChangeMining</artifactId>
    <version>0.0.1-SNAPSHOT</version>
    <repositories>
        <repository>
            <id>local-maven-repo</id>
            <url>file:///Users/xx/Documents/Research_Topic_2/</url>
        </repository>
    </repositories>
    <build>
        <sourceDirectory>src</sourceDirectory>
        <plugins>
            <plugin>
                <artifactId>maven-compiler-plugin</artifactId>
                <version>3.5.1</version>
                <configuration>
                    <source>11</source>
                    <target>11</target>
                </configuration>
            </plugin>
            <plugin>
                <groupId>org.apache.maven.plugins</groupId>
                <configuration>
                    <source>11</source>
                    <target>11</target>
                </configuration>
            </plugin>
        </plugins>
    </build>
    <dependencies>
        <!--Below is the locally built jdt core jar -->
        <dependency>
            <groupId>org.eclipse.jdt</groupId>
            <artifactId>org.eclipse.jdt.core</artifactId>
            <version>3.23.0-SNAPSHOT</version>
        </dependency>
        <dependency>
            <groupId>org.eclipse.core</groupId>
            <artifactId>runtime</artifactId>
            <version>3.10.0-v20140318-2214</version>
        </dependency>
        <dependency>
            <groupId>org.eclipse.birt.runtime</groupId>
            <artifactId>org.eclipse.core.resources</artifactId>
            <version>3.10.0.v20150423-0755</version>
        </dependency>
        <dependency>
            <groupId>org.eclipse</groupId>
            <artifactId>osgi</artifactId>
            <version>3.10.0-v20140606-1445</version>
        </dependency>
    </dependencies>
</project>
Re: java.lang.NoSuchMethodError in JDT Core runtime [message #1831299 is a reply to message #1831294] Mon, 17 August 2020 05:04 Go to previous message
After experimenting with couple of versions of org.eclipse..runtime, I could successfully run my project with the locally built JDT Core. However I have no idea for the existence of couple of maven repositories for org.eclipse.core.runtime.
I removed below dependency
        <dependency>
        </dependency>
I added below dependency.
		<dependency>
			<artifactId>org.eclipse.birt.runtime</artifactId>
			<version>4.6.0-20160607</version>
		</dependency>
I would be grateful to you, If somebody can explain the reason for maintaining multiple maven repositories for `org.eclipse.core`. Thank you.
Previous Topic:BUG: Tomcat launched from Eclipse does not respect Tomcat's deploy order
Next Topic:Building eclipse JDT core
Current Time: Wed Jun 16 18:35:09 GMT 2021
Powered by FUDForum. Page generated in 0.02320 seconds
