Re: Question regarding mapping of components and parameters [message #1831282 is a reply to message #1831279] |
Sun, 16 August 2020 13:17 |
Gábor Szalai Messages: 131 Registered: December 2015 |
I tried to test it, but the map param works from function for me.
See the small attached example. Can you try it?
You can check the generated code also.
Code generated for map without param:
Map_Params tmp_4(0);
TTCN_Runtime::map_port(self, CT_component_p1.get_name(), SYSTEM_COMPREF, "p2", tmp_4);
Code generated for map with param, see the set_param call:
Map_Params tmp_2(1);
tmp_2.set_param(0, ttcn_to_string(INTEGER(23)));
TTCN_Runtime::map_port(self, CT_component_p1.get_name(), SYSTEM_COMPREF, CTS_component_p2.get_name(), tmp_2);
Re: Question regarding mapping of components and parameters [message #1831314 is a reply to message #1831311] |
Mon, 17 August 2020 09:57 |
Hi Moritz,
a quick question: which actual test port do you intend to use?
The Titan test ports we have published so far have no support for "map param" so parameters will not propagate to the test port.
They are configured either statically, via the config file, or dynamically , via purposeful messages sent to the test port.
Best regards
Elemer
Re: Question regarding mapping of components and parameters [message #1838676 is a reply to message #1831322] |
Wed, 03 March 2021 13:21 |
Moritz Klass Messages: 22 Registered: August 2020 |
Hey all, sorry, to reopen this issue. I am now returning to this project.
In the referenced bug ticket the two bugs are reported as closed. My ttcn_compiler version is 7.2.pl0 and the bug seems to be still there (and extended).
I am now using the parallel runtime. The TTCN code is the following:
log("Going to pass ", vc_tcp_tls_parameter);
map(self:pt_TCP_TLS_SEC_Port, system:pt_TCP_TLS_SEC_Port)
param (vc_tcp_tls_parameter);
and the generated C code is the following:
Map_Params tmp_6(0);
TTCN_Runtime::map_port(self, ComponentsAndPorts::SEC__Tester_component_pt__TCP__TLS__SEC__Port.get_name(), SYSTEM_COMPREF, ComponentsAndPorts::SystemSEC_component_pt__TCP__TLS__SEC__Port.get_name(), tmp_6);
I am not able to receive the parameter in the port, despite using the self (or the mtc, too) component.
BR,
Moritz
[Updated on: Wed, 03 March 2021 13:23] Report message to a moderator
FUDForum. Page generated in 0.04276 seconds
