Home » Eclipse Projects » Eclipse Titan » TTCN-3 compiler error on activate() function(TTCN-3 default activate)
TTCN-3 compiler error on activate() function [message #1831028] Mon, 10 August 2020 07:43 Go to next message
Yann Garcia is currently offline Yann GarciaFriend
Member
Since my last TITAN code update/rebuild, I have the following error on TTCN-3 function 'activate()':
error: Reference with actual parameter list was expected in the argument
The code looks like (ETSI ITS Test Suite):
vc_default := activate(LibItsCam_Functions.a_utDefault());
With vc_default declared in test component as:
var default vc_default := null;
Do you have any idea?
Thanks a lot,
Yann Garcia
Re: TTCN-3 compiler error on activate() function [message #1831033 is a reply to message #1831028] Mon, 10 August 2020 10:27 Go to previous messageGo to next message
Elemer Lelik is currently offline Elemer LelikFriend
Hi Yann,
I have created a TR in Bugzilla:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=565947
that you can follow; we will investigate soonest.
Thank you and best regards
Elemer
Re: TTCN-3 compiler error on activate() function [message #1831038 is a reply to message #1831033] Mon, 10 August 2020 13:05 Go to previous messageGo to next message
Hi Yann,
meanwhile Botond also created a bug
https://bugs.eclipse.org/bugs/show_bug.cgi?id=565952
so I marked the mine as duplicate.
The solution is under review and will be available within a day or two on the latest github source.
BR
Elemer
Re: TTCN-3 compiler error on activate() function [message #1831040 is a reply to message #1831038] Mon, 10 August 2020 13:31 Go to previous message
Member
Thanks a lot ;)
Yann
Previous Topic:Translation ports vs dual-faced ports part1
Next Topic:External functions using universal charstrings
Current Time: Sat Jul 31 05:25:35 GMT 2021
Powered by FUDForum. Page generated in 0.02291 seconds
