Home » Modeling » TMF (Xtext) » Support of OSGI DS 1.3 annotations in Xtend?
Support of OSGI DS 1.3 annotations in Xtend? [message #1830851] Wed, 05 August 2020 09:28 Go to next message
Zakir Meer is currently offline Zakir MeerFriend
Member
Is there a support for OSGI DS 1.3 annotations in Xtend.
When I have added OSGI annotations in Xtend file I am getting compilation errors please have a look at the attached screenshot
index.php/fa/38731/0/
Re: Support of OSGI DS 1.3 annotations in Xtend? [message #1830853 is a reply to message #1830851] Wed, 05 August 2020 09:44 Go to previous messageGo to next message
Christian Dietrich is currently offline Christian DietrichFriend
depends on the type of annotations, we dont support Java 8 type annotations https://github.com/eclipse/xtext-extras/issues/218 https://bugs.eclipse.org/bugs/show_bug.cgi?id=443305
Twitter : @chrdietrich
[Updated on: Wed, 05 August 2020 10:13]
Report message to a moderator
Re: Support of OSGI DS 1.3 annotations in Xtend? [message #1830855 is a reply to message #1830853] Wed, 05 August 2020 10:09 Go to previous messageGo to next message
p.s: the syntax for a list/array is #[] and not {}
so for annotations on classes this should work
@Component(
property=#[
"x",
"Y",
"z"
Re: Support of OSGI DS 1.3 annotations in Xtend? [message #1830856 is a reply to message #1830855] Wed, 05 August 2020 10:30 Go to previous message
Member
Hi Christian,
Thanks for the quick reply. It worked, as you mentioned I changed the syntax as per Xtend.
index.php/fa/38733/0/
[Updated on: Wed, 05 August 2020 10:30]
Previous Topic:Possible to convert part of STRING to an object's ID using a value converter?
Next Topic:Standalone XBase DSl with Compile Time Java Source (.java) and Jar (.class file) Dependencies
Current Time: Tue Apr 16 23:13:29 GMT 2024
Powered by FUDForum. Page generated in 2.51159 seconds
