Re: Eclipse changes my Code [message #1830811 is a reply to message #1830791] |
Tue, 04 August 2020 15:08 |
john hanly Messages: 2 Registered: August 2020 |
Yes, i have the following code directly from the book.
package array2d;
public class Array2D {
// TODO Auto-generated method stub
//Basic test
int [][] test1 = new int[4][5];
test1[0][0] = 5;
test1[1][3] = 3;
System.out.println("The row length is " + test1.length);
System.out.println("The colunm length is " + test1[0].length);
//Search using counters
int z = 0;
// int[][] test2 = { { 3, 2, 6, 5 }, { 2, 7, 8, 1 }, { 4, 2, 7, 2 } };
int[][] test2 = { { 3, 2, 6, 5 }, { 2, 7 }, { 4, 2, 7, 2 }, { 7, 9, 2, 1, 6, 5 } };
//Counter search
for (int[] element : test2) {
for (int y = 0; y < element.length; y++ )
if(element[y] == 2)
z++;
System.out.println("The number 2 was found " + z + " times");
//Enhanced for-loop search
z=0;
for (int x[] : test2)
for(int y : x)
if (y == 7)
z++;
System.out.println("The number 7 was found " + z + " times");
Under the comment Counter Search the following 4 lines have the word 'element' in them. The original lines after counter search were:
for ( int x = 0; x< test2.length; x++) {
for (int y = 0;y< test2[x].length; y++) {
if ( test2[x][y] == 2) {
z++;
i understand the added lines are a shorter way of doing the double loop but i need the original code to follow the book. If you replace the lines after Counter search with these lines you'll have the original code.
thanks
FUDForum. Page generated in 0.03434 seconds
