Home » Language IDEs » C / C++ IDE (CDT) » Deduced class template argument & fold expression syntax
Deduced class template argument & fold expression syntax [message #1830769] Mon, 03 August 2020 12:16
I have some code like
// include ... & using std
template<typename ... T>
enable_if_t<(is_same_v<T, int> && ...)> test(T ... ts) { /* ... */ }
vector v{1, 2, 3, 4};
// main ...
where the test function uses a fold expression and the vector uses template argument deduction. These compile under gcc 10.1.0 with -std=c++17.
However Eclipse (I just updated to 2020-06) shows the fold expression as syntax error and gives a "Type ... could not be resolved" error for the vector. Is this a missing implementation in Eclipse itself or is it something wrong with my settings?
* If it is a limitation of Eclipse, is there any way I can at least disable these errors without turning them off completely or polluting my code with // @suppress comments? E.g. some regex for which syntax should not be checked?
* Alternatively a pointer to where one might implement this in the CDT would also be nice .. though I imagine this would be some work.
Previous Topic:SOLVED QGuiApplication missing in 2020=03
Next Topic:Eclipse CDT Python PyDev plug-in - where to enable icons ?
Current Time: Fri Nov 07 05:48:02 EST 2025
Powered by FUDForum. Page generated in 0.04518 seconds
