Home » Polarsys » Capella General » Requirements diagram
Requirements diagram [message #1830622] Thu, 30 July 2020 04:24 Go to next message
Abhijith Sriram is currently offline Abhijith SriramFriend
Hey everyone. I am very new to MBSE and CAPELLA. I am trying to see how MBSE works and how I can implement in my workplace. I have a question regarding the requirements diagram in capella. I cannot seem to find a specific diagram related to capturing text based requirements. Although there is a requirements package option and after creating a package i try to create a requirements table. Unfortunately I cannot seem to edit the cells foe some reason. Am i missing something here? Can anyone point me in the right direction please. Thank you :)
Re: Requirements diagram [message #1830653 is a reply to message #1830622] Thu, 30 July 2020 14:19 Go to previous messageGo to next message
James Tooke is currently offline James TookeFriend
For using the build in requirements it sounds like you are very nearly there.
  1. Create a Requirements Package in the Project Explorer
  2. Then right click on the Requirements Package and under the "New diagram/Table" menu create a new "Requirements" table
  3. Then from the Project Explorer right click on the Requirements Package and under "Add Capella Element" add a requirement of the type you want
  4. You can do the same from inside the Requirements table - just right click on the Requirement Package icon
  5. Once you have a requirement you will be able to edit it's details either in the table or in the Properties panel at the bottom of the screen.
There is also the Requirements Viewpoint Plug-In (https://www.eclipse.org/capella/addons.html), which is worth looking at and provides another approach. It provides the ability to import Requirements from a ReqIF file. This means that you can do the management of your textual requirements in the RM tool of your choosing, then import them to Capella so they can be linked to the relevant parts of the model.
Hope that helps
Re: Requirements diagram [message #1830662 is a reply to message #1830653] Thu, 30 July 2020 17:03 Go to previous messageGo to next message
Stephane LACRAMPE is currently offline Stephane LACRAMPEFriend
Hi Abhijith,
Yes if you want to use Requirements with Capella, I strongly advise you to use the Requirements Viewpoint as the other Requirements data information is more a legacy one. With the viewpoint, you'll be able to display requirements in any Capella diagram, see here for an example: https://www.eclipse.org/capella/arcadia_capella_sysml_tool.html#requirement
Stephane
All the best,
Stephane
Stephane LACRAMPE
Obeo Canada
Re: Requirements diagram [message #1830958 is a reply to message #1830662] Fri, 07 August 2020 10:44 Go to previous messageGo to next message
Fábio Guarita is currently offline Fábio GuaritaFriend
Member
Stephane, I've seen some forum posts about the legacy requirements tool and how it is better to ignore it and use the requirements extension.
Wouldn't be better to just have the option of not showing any information (contextual menus, etc...) regarding the legacy implementation? I know it is probably not the fanciest development for next releases but I just wonder if you have it as some 'improvement proposal' for next releases (I don't know eclipse lingo for that)
Re: Requirements diagram [message #1830976 is a reply to message #1830958] Fri, 07 August 2020 15:28 Go to previous messageGo to next message
Yes you can raise a bugzilla here selecting "enhancement" for the severity: https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Capella
Stephane LACRAMPE
Obeo Canada
Re: Requirements diagram [message #1831095 is a reply to message #1830976] Tue, 11 August 2020 16:55 Go to previous messageGo to next message
Member
Thank you, I'll add it there as an idea for future developments.
Re: Requirements diagram [message #1835701 is a reply to message #1830622] Thu, 10 December 2020 16:51 Go to previous messageGo to next message
Lara QASIM is currently offline Lara QASIMFriend
I am wondering why I can't create requirements package within capella tool.
In the project explorer, when I select the system analysis icon and then I right click, I only have new representation , but there is no option for a new capella element and then Requirements PKG?
Thank you in advance,
Lara
Re: Requirements diagram [message #1835704 is a reply to message #1835701] Thu, 10 December 2020 17:58 Go to previous message
Hi Lara,
I suggest you post your question in the new Capella forum: https://forum.mbse-capella.org/
All the best,
Stephane
Stephane LACRAMPE
Obeo Canada
Previous Topic:Addon/Viewpoint to support STAMP or STPA for safety and security analysis
Next Topic:Links on the Documentation tab
Current Time: Mon Jul 26 18:19:08 GMT 2021
Powered by FUDForum. Page generated in 0.02133 seconds
