Synchronize changes from the Model to the Embedded Editor in Xtext [message #1830598] |
Wed, 29 July 2020 14:28 |
Georgiana Ecobici Messages: 23 Registered: July 2019 |
I used XText to define a DSL Grammar, then I used the XText EmbeddedEditor to use XText editor in it.
I have some issues regarding the synchronization, I obtained the model object that contains my content inside the XText editor, but If I modify in Java directly my Model object, the changes are not reflected in the EmbeddedEditor.
The model is updated like below:
DslscenarioProvider p = eeView.getProvider();
XtextResource resource = p.getResource();
EList<EObject> content = resource.getContents();
if (content.size() > 0 && content.get(0) instanceof Model) {
Model domainModel = (Model) resource.getContents().get(0);
Type type = domainModel.getType();
if (type != null) {
type.setName("test");
resource.relink();
The EmbeddedEditor is added inside an Eclipse ViewPart:
public class EmbeddedEditorView extends ViewPart {
public void redrawParent() {
getParent().redraw(); // parent = composite
public void createPartControl(Composite parent) {
top = new Composite(parent, SWT.NONE);
top.setLayout(new GridLayout());
DslscenarioActivator activator = DslscenarioActivator.getInstance();
Injector injector = activator .getInjector(DslscenarioActivator.ORG_EDITOR_DSLSCENARIO_DSL);
provider = injector.getInstance(DslscenarioProvider.class);
EmbeddedEditorFactory factory = injector.getInstance(EmbeddedEditorFactory.class);
EmbeddedEditor editor = factory.newEditor(provider).withParent(top);
model = editor.createPartialEditor("", "", "", false);
The redrawParent is called after doing some changes on the model object, however the view is not updated, even if the model is updated.
Do you have other suggestions?
FUDForum. Page generated in 0.02767 seconds
