Home » Polarsys » Capella General » Capella 1.4.1 has been released
Capella 1.4.1 has been released [message #1830478] Mon, 27 July 2020 14:24 Go to next message
Philippe Dul is currently offline Philippe DulFriend
Hello everyone,
Capella 1.4.1 has been released.
The release notes for Capella 1.4.1 is available on this Wiki page [1]
Capella 1.4.1 is available for download on the Capella website [2]
Philippe
[1] https://github.com/eclipse/capella/releases/tag/v1.4.1
[2] https://www.polarsys.org/capella/download.html
Re: Capella 1.4.1 has been released [message #1830484 is a reply to message #1830478] Mon, 27 July 2020 17:51 Go to previous messageGo to next message
Stephane LACRAMPE is currently offline Stephane LACRAMPEFriend
Weel done guys!
Stephane LACRAMPE
Obeo Canada
Re: Capella 1.4.1 has been released [message #1833539 is a reply to message #1830484] Fri, 16 October 2020 09:49 Go to previous messageGo to next message
richard corbie is currently offline richard corbieFriend
Hello all together,
two questions:
1) What about the AddOns? Can the 1.4.0-Versions (there are no newer available yet) be used with Capella 1.4.1 (and 1.4.2 in the future)?
(once there was a compatibility-matrix - can not find it...)
2) Model-Migration: can e.g. a 1.3.1 model be migrated directly to 1.4.1 or has it to be migrated first to 1.4.0?
Kind regards
Re: Capella 1.4.1 has been released [message #1833546 is a reply to message #1833539] Fri, 16 October 2020 12:31 Go to previous messageGo to next message
Hi Richard,
Here is the link to the compatibility matrix: https://wiki.eclipse.org/Capella/Addons but it won't give you much answers to your question.
Here is the level of info I have:
For capella 1.4.1, you should take the 1.4.1 version of the add-ons if there is one, otherwise the 1.4.0 version. The 1.4.1 version of the addons have not been moved to the release directory, so you should look for them in the "stable" directory. Example:
https://download.eclipse.org/capella/addons/xhtmldocgen/updates/stable/1.4.1/
Please also note that there is a Capella 1.4.2 version which is about to be released, coming with a few interesting bug fixes: https://github.com/eclipse/capella/releases/tag/v1.4.2-S20201014 :
Richtext edition improvements
Performance improvements
REC/RPL fixes
Transitions fixes
Some of the addons are going to be released for Capella 1.4.2: docgen xhtml, filtering, system to sub-system transition but the rest of them that were working with 1.4.1 will work with 1.4.2
I hope this helps
Stephane LACRAMPE
Obeo Canada
Re: Capella 1.4.1 has been released [message #1833547 is a reply to message #1833546] Fri, 16 October 2020 12:32 Go to previous message
I forgot your second question. I advise to do first the migration to 1.4.0 and then the migration to 1.4.1.
Stephane LACRAMPE
Obeo Canada
Previous Topic:Physical quantities and numbers
Next Topic:Open MBEE test MMS repository login\password
Current Time: Tue May 18 05:35:08 GMT 2021
Powered by FUDForum. Page generated in 0.02196 seconds
