Home » Eclipse Projects » Remote Application Platform (RAP) » Strange behaviour for ComboBox and TabFolder
Strange behaviour for ComboBox and TabFolder [message #1830412] Sat, 25 July 2020 14:30 Go to next message
Dmitry Dukhov is currently offline Dmitry DukhovFriend
created standard window(parent TabFolder) with widgets
inside code with widgets, ran ProgressMonitorDialog
.... And Error.
Attention!!!
1.If Change TabFolder to CTabFolder to That's all right!!!!
2. If change Combo to other widget (for example Label) that's all right too and with TabFolder.
I don't understand where is mistake. Combination Combo and TabFolder doesn't work
Dmitry
Error: Error: Operation "create" on target "w2680" of type "null" failed:
Cannot read property 'addEventListener' of null
Properties:
parent = w2669
style = DROP_DOWN
children =
bounds = 0,0,0,0
tabIndex = 1479
visibleItemCount = 30
items = Any,ARCHIVE+BACKUP,RESTORE+RETRIEVE,ARCHIVE,BACKUP,DBBACKUP,DELETE FILESPACE,EXPIRATION,IMPORT+EXPORT,MOVE DATA,MOVE NODEDATA,MIGRATION,OFFSITE RECLAMATION,POOLPRIMUTILGB,RETRIEVE,RESTORE,RECLAMATION,REPLICATION,STGPOOL BACKUP,SHREDDING,TAPE MOUNT
selectionIndex = 0
editable = false
  Stack: Error: Operation "create" on target "w2680" of type "null" failed:
Properties:
parent = w2669
style = DROP_DOWN
children =
bounds = 0,0,0,0
tabIndex = 1479
selectionIndex = 0
editable = false
    at Object._processError (https://127.0.0.1:5020/rwt-resources/3130/rap-client.js:226:3814)
    at Object.processOperationArray (https://127.0.0.1:5020/rwt-resources/3130/rap-client.js:226:924)
    at Object.processMessage (https://127.0.0.1:5020/rwt-resources/3130/rap-client.js:226:253)
    at Object._handleSuccess (https://127.0.0.1:5020/rwt-resources/3130/rap-client.js:230:3677)
    at rwt.remote.Request._success (https://127.0.0.1:5020/rwt-resources/3130/rap-client.js:98:925)
    at rwt.remote.Request._onReadyStateChange (https://127.0.0.1:5020/rwt-resources/3130/rap-client.js:98:1596)
    at XMLHttpRequest. (https://127.0.0.1:5020/rwt-resources/3130/rap-client.js:7:219)
  Debug: off
  Request: {"head":{"requestCounter":118},"operations":[["set","w965",{"selection":["w1140"]}],["notify","w965","Selection",{"item":"w1140","button":1,"shiftKey":false,"ctrlKey":false,"altKey":false}],["set","w965",{"focusItem":"w1140","focusCell":0}],["notify","w965","MouseDown",{"x":92,"y":644,"time":360530,"button":1,"shiftKey":false,"ctrlKey":false,"altKey":false}],["set","w1",{"cursorLocation":[92,644]}]]}
Re: Strange behaviour for ComboBox and TabFolder [message #1830416 is a reply to message #1830412] Sat, 25 July 2020 16:09 Go to previous messageGo to next message
Ivan Furnadjiev is currently offline Ivan FurnadjievFriend
please open a bugzilla and provide a snippet to reproduce the error.
Thanks in advance,
Ivan
Re: Strange behaviour for ComboBox and TabFolder [message #1862513 is a reply to message #1830416] Fri, 08 December 2023 10:50 Go to previous message
I see link to my old post. I don't exactly remember how to decided this problem but it was be releated with initialisation order for widgets before other operations (Especcially with progressbar operations and threads) and there were the problems exacly with combo widget. Why? I don't know. Try check an initialisation data for Combo. Maybe you create Combo in one place but set data for them in other
Previous Topic:RAP 4.26 with Eclipse RCP and RAP IDE does not find org.eclipse.swt.widgets.Display
Next Topic:Client Error : Cannot read properties of undefined
Current Time: Sun Sep 15 08:08:33 GMT 2024
Powered by FUDForum. Page generated in 0.03211 seconds
