Fuzzy grammar advice [message #1829942] |
Tue, 14 July 2020 14:01 |
Tomas Öberg Messages: 14 Registered: February 2020 |
I'm wondering how to best implement a grammar that skips statements and expressions (and their descendants) and just parses at the surface level of the code. In other words I only want to parse classes/objects with their fields and method names but I don't want to meddle with the expressions in this fuzzy parser version.
The language I'm creating an xtext based LS for, has its methods defined within brackets, as for example:
functionId[ param1 param2 paramN;
...stat/expr...<--- skip all of these
And the global function's syntax looks like:
[globalFunctionId param1 param2 paramN;
...stat/expr... <--- skip all of these
My (flawed) solution so far has been to create a BRACKET_TO_BRACKET terminal:
terminal BRACKET_TO_BRACKET:
But the disadvantage is of course that the ']' token can appear within a string statement, such as "[Text]" and break up the parsing halfway.
Luckily though the language doesn't use brackets for array elements so it is probably only the strings that will require special handling.
I'm under the impression that this is hard to do by grammar and that I might need to override the lexer with my own variant of it, but cannot say for sure. It might just be that I haven't thought long enough on how accomplish this yet. But IF I need to override the Lexer Ive noticed that it turns all its rules to final methods making it even harder to override the specific mBRACKET_TO_BRACKET function I want to customize. Where can the final modifier be turned off in case there isn't a better way forward?
(Any suggestions whatsoever in how accomplish the end goal here is most welcome.)
[Updated on: Tue, 14 July 2020 14:12] Report message to a moderator
Re: Fuzzy grammar advice [message #1829946 is a reply to message #1829942] |
Tue, 14 July 2020 15:13 |
Right, if you can't use a single token to be consumed by the standard lexer, you'll have to use your custom lexer.
There are a couple of articles and projects out there where you could get some inspiration from. In Xtext's code base custom lexing is done in the Xtend language (org.eclipse.xtend.core).
Since 2.20 a new generator fragment org.eclipse.xtext.xtext.generator.parser.antlr.ex.ExternalAntlrLexerFragment exists to embed the basic bindings to customize external lexers.
Re: Fuzzy grammar advice [message #1829982 is a reply to message #1829972] |
Wed, 15 July 2020 08:53 |
Thanks to you both! I think I'll try out the retokenizer approach first and go for the custom lexer if it fails. Do you know Ed if that approach will work equally well if I were to apply the same for a language where the syntax was more alike c/java when it comes to functions, i.e blocks within curly braces { ... } ? And do you know if there is any drawbacks to this method that I wouldn't get with the custom lexer?
[Updated on: Wed, 15 July 2020 09:36] Report message to a moderator
FUDForum. Page generated in 0.03226 seconds
