Home » Polarsys » Capella Studio » create a matrix as a diagram like the for traceability or allocation
create a matrix as a diagram like the for traceability or allocation [message #1829903] Mon, 13 July 2020 15:37 Go to next message
Soulimane KAMNI is currently offline Soulimane KAMNIFriend
Hi everyone,
Is there a way to create a matrix as a diagram, that should take as rows the logical functions and for the columns, the physical component. The intersections cells would take integer values instead of an "X".
The diagram extension in the diagram.vptext file doesn't suggest any matrix to be extended.
index.php/fa/38575/0/
index.php/fa/38576/0/
  • Attachment: matrix.jpg
    (Size: 37.50KB, Downloaded 431 times)
  • Attachment: pexplorer.jpg
    (Size: 55.39KB, Downloaded 443 times)
[Updated on: Mon, 13 July 2020 15:39]
Report message to a moderator
Re: create a matrix as a diagram like the for traceability or allocation [message #1829904 is a reply to message #1829903] Mon, 13 July 2020 16:09 Go to previous message
Stephane LACRAMPE is currently offline Stephane LACRAMPEFriend
Hi Soulimane,
You can have a look at this thread where you'll find ax exemple of how you can do it: https://www.eclipse.org/forums/index.php/t/1102688/
(This is not exactly answering your question, this is more a workaround)
Stephane
Stephane LACRAMPE
Obeo Canada
[Updated on: Mon, 13 July 2020 16:10]
Previous Topic:Restrict the number of instances of an extension element
Next Topic:Capella Studio 1.4.1 ?
Current Time: Fri Sep 29 21:32:37 GMT 2023
Powered by FUDForum. Page generated in 0.02660 seconds
