Home » Polarsys » Capella General » XHTML add-on export table typo(M&S diagram description on XHTML export has typo)
XHTML add-on export table typo [message #1829737] Thu, 09 July 2020 19:39 Go to next message
Fábio Guarita is currently offline Fábio GuaritaFriend
Member
Since there is no forum specific to the XHTML export add-on project I'll post this here.
The table that specifies transitions on XHTML export has a typo for "Trigger" field. It is missing an 'r' so the label "Tigger" appears on the export.
index.php/fa/38538/0/
It seems the "issues" tracker on XHTML github page has never been used so... if any maintainer of the add-on is reading this, can you fix this? It seems to be in the files below:
index.php/fa/38539/0/
Thanks!
Re: XHTML add-on export table typo [message #1829749 is a reply to message #1829737] Fri, 10 July 2020 07:32 Go to previous messageGo to next message
Arnaud Dieumegard is currently offline Arnaud DieumegardFriend
You are right there is indeed a typo. Thanks for reporting !
Regarding the "issues" tracking we use the Eclipse bugzilla: https://bugs.eclipse.org/bugs/enter_bug.cgi?product=Capella (do not forget to set the component field to Gendoc HTML). Thanks for this, I just added a Github issue regarding issues filling !
Arnaud
Re: XHTML add-on export table typo [message #1829772 is a reply to message #1829749] Fri, 10 July 2020 11:39 Go to previous message
Member
Thank you for the bugzilla link Arnaud! Just added the issue to the bugzilla tracker.
I won't bug (pun intended) you guys on the forums again about this :D
Previous Topic:Human Factors // Human Systems Integration
Next Topic:REF calls in diagrams: expected behaviour
Current Time: Sat Jul 24 18:44:16 GMT 2021
Powered by FUDForum. Page generated in 0.02093 seconds
