Home » Archived » Jubula » Establishing Connection to AUT failed(5009: AUT Start Failed)
Establishing Connection to AUT failed [message #1829710] Thu, 09 July 2020 10:37 Go to next message
Christine S is currently offline Christine SFriend
Hi Everyone !
I'm newbie in Jubula. Please help me to fix this issue :
5009: AUT start failed
Establishing connection to AUT failed.
Please check the AUT configuration. AUTServer could not start: Establishing communication failed.
-- Application to be tested : JSP with running text html and applet inside
-- Jubula standalone, version 8.7.1.046
-- Java version 1.6
-- IE version 11
I already tried to make AUT Configuration as seen in Capture.PNG. But when I click Try AUT, the running text is showed up. But the applet not showed up. (Capture2.PNG)
In Internet Explorer, my applet is running well.
Please give me advice if I had wrong configuration.
Thank you before.
Christine
  • Attachment: Capture.PNG
    (Size: 30.72KB, Downloaded 72 times)
  • Attachment: Capture2.PNG
    (Size: 2.35KB, Downloaded 76 times)
Re: Establishing Connection to AUT failed [message #1829857 is a reply to message #1829710] Mon, 13 July 2020 07:10 Go to previous messageGo to next message
Marvin Mueller is currently offline Marvin MuellerFriend
The newer Versions of Jubula do not support Website testing anymore. I would suggest you to use other tools and to begin testing websites
best regards
Marvin Mueller
Re: Establishing Connection to AUT failed [message #1829919 is a reply to message #1829857] Tue, 14 July 2020 02:31 Go to previous message
Oic, Thank you for your info. Do you know what is the best tool for testing website with applet inside ?
Previous Topic:Object Mappping not working for JavaFX AUT using javax.swing
Next Topic:Toolkit extension Jubula
Current Time: Sun Feb 25 06:49:07 GMT 2024
Powered by FUDForum. Page generated in 0.03481 seconds
