Home » Newcomers » Newcomers » Windows 10 Java 64(Can't install Eclipse)
Windows 10 Java 64 [message #1829690] Thu, 09 July 2020 00:03 Go to next message
Jeff Schueller is currently offline Jeff SchuellerFriend
Ok I have verified Java is installed:
C:\Users\Jeff>java -version
java version "1.8.0_251"
Java(TM) SE Runtime Environment (build 1.8.0_251-b08)
Java HotSpot(TM) Client VM (build 25.251-b08, mixed mode, sharing)
Eclipse installer still says it is not there. Any Ideas??
Re: Windows 10 Java 64 [message #1829694 is a reply to message #1829690] Thu, 09 July 2020 01:23 Go to previous messageGo to next message
Nitin Dahyabhai is currently offline Nitin DahyabhaiFriend
This is a little difficult to confirm, but I think it would identify itself as a 64-bit JRE if it were one, and current releases require (and the installer looks for) a 64-bit JRE.
Nitin Dahyabhai
Eclipse Web Tools Platform
Re: Windows 10 Java 64 [message #1829696 is a reply to message #1829694] Thu, 09 July 2020 03:56 Go to previous messageGo to next message
Yes, my 32 bit VM prints things:
$/c/Program\ Files\ \(x86\)/Java/jdk1.8.0_101/bin/java.exe -version
java version "1.8.0_101"
Java(TM) SE Runtime Environment (build 1.8.0_101-b13)
Java HotSpot(TM) Client VM (build 25.101-b13, mixed mode)
But a 64 bit one prints this:
$java -version
java version "1.8.0_121"
Java(TM) SE Runtime Environment (build 1.8.0_121-b13)
Java HotSpot(TM) 64-Bit Server VM (build 25.121-b13, mixed mode)
Ed Merks
Re: Windows 10 Java 64 [message #1829714 is a reply to message #1829696] Thu, 09 July 2020 12:18 Go to previous message
Thanks everyone. The issue WAS ther flipping java installed the 32 even though I selected 64. I diff ther manual install and everything works. I even made the test watch face. I have a lot to learn and relearn. It's amazing how getting older and not doing something for just a few years can make you totally forget even ther easiest things. But on the bright side, I can still remember calculus.
Previous Topic:Eclipse IDE strange behavior
Next Topic:What JVM config options does Eclipse insert into application?
Current Time: Sun Jan 17 11:04:56 GMT 2021
Powered by FUDForum. Page generated in 0.02789 seconds
