Home » Eclipse Projects » EGit / JGit » Unable to connect using SSH in JGit(Unable to connect using SSH in JGit)
Unable to connect using SSH in JGit [message #1829533] Mon, 06 July 2020 05:31 Go to next message
I am trying to connect to github.com using SSH and JGit. This is the code I am trying:-
public static void gitClone(File gitDirectoryPath) throws Exception {
SshSessionFactory sshSessionFactory = new JschConfigSessionFactory() {
protected void configure(OpenSshConfig.Host host, Session session) {
session.setUserInfo(new UserInfo() {
public String getPassphrase() {
return "";
public String getPassword() {
return null;
public boolean promptPassword(String message) {
return false;
public boolean promptPassphrase(String message) {
return true;
public boolean promptYesNo(String message) {
return false;
public void showMessage(String message) {
Git.cloneRepository().setTransportConfigCallback(new SshTransportConfigCallback()).setURI("git@github.com:agarwalvipul/core-java-template.git")
.setDirectory(gitDirectoryPath).call();
private static class SshTransportConfigCallback implements TransportConfigCallback {
private final SshSessionFactory sshSessionFactory = new JschConfigSessionFactory() {
protected void configure(OpenSshConfig.Host hc, Session session) {
session.setConfig("StrictHostKeyChecking", "no");
public void configure(Transport transport) {
SshTransport sshTransport = (SshTransport) transport;
sshTransport.setSshSessionFactory(sshSessionFactory);
I am getting the following exception:-
Exception in thread "main" org.eclipse.jgit.api.errors.TransportException: git@github.com:agarwalvipul/core-java-template.git: Auth fail
at org.eclipse.jgit.api.FetchCommand.call(FetchCommand.java:252)
at org.eclipse.jgit.api.CloneCommand.fetch(CloneCommand.java:306)
at org.eclipse.jgit.api.CloneCommand.call(CloneCommand.java:200)
at com.lm.expertfees.Github.gitClone(Github.java:60)
at com.lm.expertfees.Test.main(Test.java:10)
Caused by: org.eclipse.jgit.errors.TransportException: git@github.com:agarwalvipul/core-java-template.git: Auth fail
at org.eclipse.jgit.transport.JschConfigSessionFactory.getSession(JschConfigSessionFactory.java:182)
at org.eclipse.jgit.transport.SshTransport.getSession(SshTransport.java:140)
at org.eclipse.jgit.transport.TransportGitSsh$SshFetchConnection.<init>(TransportGitSsh.java:280)
at org.eclipse.jgit.transport.TransportGitSsh.openFetch(TransportGitSsh.java:170)
at org.eclipse.jgit.transport.FetchProcess.executeImp(FetchProcess.java:137)
at org.eclipse.jgit.transport.FetchProcess.execute(FetchProcess.java:123)
at org.eclipse.jgit.transport.Transport.fetch(Transport.java:1269)
at org.eclipse.jgit.api.FetchCommand.call(FetchCommand.java:241)
... 4 more
Caused by: com.jcraft.jsch.JSchException: Auth fail
at com.jcraft.jsch.Session.connect(Session.java:519)
at org.eclipse.jgit.transport.JschConfigSessionFactory.getSession(JschConfigSessionFactory.java:136)
... 11 more
Can anyone help me in this context?
Re: Unable to connect using SSH in JGit [message #1859065 is a reply to message #1829533] Wed, 10 May 2023 03:17 Go to previous messageGo to next message
Hi All,
I'm facing the same issue while trying to pull through SSH in jgit.
The key files are correct, double checked it.
I'm setting this sessionFactory.
pull.setTransportConfigCallback(transport -> ((SshTransport)transport).setSshSessionFactory(sshSessionFactory));
Kindly advice how to proceed.
Re: Unable to connect using SSH in JGit [message #1859823 is a reply to message #1859065] Wed, 28 June 2023 15:27 Go to previous message
We don't recommend the old jsch integration [1], use the integration for the mina-sshd client [2] instead.
You can start digging from JGit's unit tests for its integration with the mina-sshd client [3].
[1] https://git.eclipse.org/r/plugins/gitiles/jgit/jgit/+/refs/heads/master/org.eclipse.jgit.ssh.jsch/
[2] https://git.eclipse.org/r/plugins/gitiles/jgit/jgit/+/refs/heads/master/org.eclipse.jgit.ssh.apache/
[3] https://git.eclipse.org/r/plugins/gitiles/jgit/jgit/+/refs/heads/master/org.eclipse.jgit.ssh.apache.test/tst/org/eclipse/jgit/transport/sshd/ApacheSshTest.java
Previous Topic:How to view the diff of a file between a local file change and a local HEAD in JGIT in a text form
Next Topic:Pull doesnt work in Git Perpective
Current Time: Tue Jun 24 19:41:11 EDT 2025
Powered by FUDForum. Page generated in 0.25094 seconds
