Providing quick fixes when IMarker are not created using Xtext's API [message #1829410] |
Thu, 02 July 2020 22:13 |
Emmanuel Chebbi Messages: 123 Registered: February 2018 |
I have a DSL which is validaded through a custom AbstractDeclarativeValidator. The editor shows error markers and I now wish to provide quick fixes.
Currently the markers are not created through the warning and error methods but "manually" through IFile::createMarker (the main reason is basically that the AST is transformed multiple times and we do not have the original EObjects/EStructuralFeature at the end). The issue is that I don't manage to make the editor aware of my quick fixes (i.e. no little bulb on which we could click).
My first try to solve the issue:
- Declare a custom marker type through the org.eclipse.core.resources.markers extension point
- Declare a custom quick fix provider through the org.eclipse.ui.ide.markerResolution extension point
Result: the Problems view shows that quick fixes are available and allows me to select one however the editor only shows the warning/error icons.
Second try:
- Extend DefaultQuickfixProvider to provide the quick fixes
- Create the Marker with some attributes I've found after digging into Xtext's source code:
val marker = file.createMarker(MyMarkers.MY_WARNING) // also tried MarkerTypes.NORMAL_VALIDATION here
marker.setAttribute(IMarker.MESSAGE, "My warning message")
marker.setAttribute(IMarker.SEVERITY, IMarker.SEVERITY_WARNING)
marker.setAttribute(IMarker.CHAR_START, 0)
marker.setAttribute(IMarker.CHAR_END, 0)
marker.setAttribute(Issue.CODE_KEY, MyMarkers.MY_WARNING)
marker.setAttribute(Issue.COLUMN_KEY, 0)
marker.setAttribute(Issue.URI_KEY, URI.createPlatformResourceURI(file.fullPath.toString, true).toString)
marker.setAttribute(IMarker.LINE_NUMBER, 0)
marker.setAttribute(IMarker.LOCATION, "line: " + 0 + " " + file.fullPath.toString())
marker.setAttribute("FIXABLE_KEY", true);
Result: the quick fix is shown in the editor and can be triggered but only when the editor has just been created. If I type anything the validator is called again and the bare warning/error icons are shown again: quick fixes are not available anymore. If I close the editor then open it again then the quick fix is shown as expected, until I type something.
I can only guess that some internal state is not set up properly and that my quick fixes are somehow discarded on refresh.
Third try:
- An old bug talks about the IResourceUIValidatorExtension interface which looks very promising. This interface is still available in Xtext's source code but I can't make it work. I tried:
- To create a bindIResourceUIValidatorExtension() method in MyDslUiModule
- To make my validator extend the interface
- To add breakpoints everywhere in MarkerUpdaterImpl
- I searched for a relevant extension point but found nothing
Result: nothing happens, the methods/classes don't seem to be used anymore.
I'm running out of new ideas so would anyone have any advise to help me solve the issue?
Many thanks,
Emmanuel
FUDForum. Page generated in 0.02284 seconds
