Home » Eclipse Projects » Eclipse Platform » Can ~/.p2 be shared between Linux and Windows on the same computer?
Can ~/.p2 be shared between Linux and Windows on the same computer? [message #1829405] Thu, 02 July 2020 16:52 Go to next message
The subject might sound strange, but my situation is the following:
I have a Windows 10 laptop with Eclipse installed. There is a ".p2" folder in %HOME% with contents populated by Eclipse.
On the same laptop, I run a Linux VM through VirtualBox. I will run similar tools on the VM, and look at similar data. I will also have Eclipse installed on the VM.
I want to do whatever I can to ensure that the diskspace used on the VM is as minimal as possible. To this end, I'm going to make ~/.m2 on the VM be a symlink to a shared folder that points to %HOME/.m2 on the laptop. That seems safe enough.
Another possible optimization is doing the same for ~/.p2 . Is there any risk in doing this?
Re: Can ~/.p2 be shared between Linux and Windows on the same computer? [message #1829414 is a reply to message #1829405] Fri, 03 July 2020 00:53 Go to previous message
If you mean the big shared bundle pool that Oomph stores there by default if you installed with the installer, so there isn't a way to share that across virtual machines. This Bug asked for that:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=544853
But I returned that as WONTFIX because it's too much work to develop and support such a feature.
Previous Topic:Missing copyright info in RCP Application
Next Topic:Install of 2020-06 on Ubuntu 18.04 VM fails with "Input is not in the XZ format"
Current Time: Fri May 23 08:38:18 EDT 2025
Powered by FUDForum. Page generated in 0.25269 seconds
