Eclipse run of spring boot project often terminates without error [message #1829356] |
Wed, 01 July 2020 21:14 |
Todd Froyland Messages: 2 Registered: July 2020 |
I have several Spring boot applications that I run out of Eclipse using the regular Java/Run option (not the Spring boot plugin). This has worked well for a long time. Recently, I upgraded to Java 11 (from 8) and upgraded to a more recent version of Spring boot (2.2.7). Now, when I try to run, I often see just <terminated> in my Console window title (no output). It goes through the normal prepare stage ("Launching Application..."), but then, just as the program should start, it stops with no errors. This is a somewhat intermittent problem, as it sometimes does run. I have not been able to determine anything I can do to make sure it runs. Occasionally, I will get a Java JVM error, including a hs error file (see attached hs_err_pid12800.log file). I do not know if that is a different issue or I just managed to get some output in this case.
I have tried changing memory parameters, including the type of garbage collection, but nothing seems to make a difference.
My Eclipse version is 2020-03.
I am at a loss as to how to troubleshoot this issue, and any suggestions would be welcome.
FUDForum. Page generated in 0.02916 seconds
