Home » Modeling » Papyrus » Background Colors in Papyrus UI(Papyrus, UI, Theme, Color)
Background Colors in Papyrus UI [message #1829244] Mon, 29 June 2020 14:28 Go to next message
Ali  Momeni is currently offline Ali MomeniFriend
I'm familiar with the usage of css to modify appearances but I'm not finding a way to change the background color of the Papyrus UI across the entire application.
Specifically, two issues:
1. In diagrams, the dark grey background make it very difficult to see the ends of connectors (like a "containment" relationship in package diagrams); the color does not appear to be modifiable with css; My preference is for white backgrounds and dark lines/strokes.
2. In the "Model Explorer", i'm not able to see the "carrot" next to an element that shows that it contains other elements and so can be uncollapsed. They appear to be white-on-white. when I select the element and it is highlighted, then I see that there is a carrot.
Any ideas?
Using:
Version: 2020-06 (4.16)
Build id: 2020-06-18T07:26:52Z
Re: Background Colors in Papyrus UI [message #1829255 is a reply to message #1829244] Mon, 29 June 2020 16:44 Go to previous messageGo to next message
Carsten Pitz is currently offline Carsten PitzFriend
Hi Ali,
what operation system with what window manager with what skin are you using.
I use Papyrus on
* Windows 10 with default window manager
* Ubuntu 18.04LTS with Gnome3 and Radiance skin
in both cases the background of the graphical editors are white.
Weird, really weird.
/Carsten
Re: Background Colors in Papyrus UI [message #1829256 is a reply to message #1829244] Mon, 29 June 2020 16:44 Go to previous messageGo to next message
Found the answer:
Preferences... > General > Appearnce > Theme > Light!
This should be the default for Papyrus as the tool is very difficult to use otherwise....
Re: Background Colors in Papyrus UI [message #1829320 is a reply to message #1829256] Wed, 01 July 2020 12:46 Go to previous message
vincent lorenzo is currently offline vincent lorenzoFriend
Hi Ali,
We don't provide black theme. Papyrus is always provided with a white background. So I don't know how you get result...
/Vincent
Previous Topic:How to design n-ary relations in Papyrus
Next Topic:Importing Diagrams as XML/XMI, or EMF, or ...
Current Time: Wed Mar 03 13:15:43 GMT 2021
Powered by FUDForum. Page generated in 0.01795 seconds
