Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Edapt migration for proxy ID changes between variables on element(Edapt migration for proxy ID changes between variables on element)
Edapt migration for proxy ID changes between variables on element [message #1829164] Fri, 26 June 2020 08:08 Go to next message
Arun Kumar is currently offline Arun KumarFriend
I have been using EDAPT and EMF for a while, I am trying to find out below operation can be done by EDAPT, I searched the documentation didnt find answer. Please help me out.
In my ecore model, I have changed the ID field (Proxy) from one variable to another variable of that class. This class has been referenced by multiple elements . How to make this migration ?
Do I need to create CUSTOM migration and collected referenced element and make modification manually ?
(E,g)
Before changes
obj 1 :  < ElementA  var1="asdf" var2="defg" />
obj2 :  < ElementB  refEleA = "asdf" />
After changes <Expected>
Since, I changed the proxy from var1 to var2, below are expected..
obj2 :  < ElementB  refEleA = "defg" />
This needs to be done only via CUSTOM migration ? How ?
Re: Edapt migration for proxy ID changes between variables on element [message #1829241 is a reply to message #1829164] Mon, 29 June 2020 13:23 Go to previous message
Johannes Faltermeier is currently offline Johannes FaltermeierFriend
Member
I think that this does not require an operation/custom migration. Simply make the changes to the ecore and make sure that the changes are recorded in the history file and make a Release.
Then you can use migrator.migrateAndLoad to load the model. In order to save references using the new id-attributes, it is best to create a fresh ResourceSet/Resource and then move the model from the migrateAndLoad-ResourceSet to the new Resource and save it.
If this does not work for you, could you please provide an example project?
Cheers
Johannes
Get professional Eclipse developer support:
http://eclipsesource.com/en/services/developer-support/
[Updated on: Wed, 01 July 2020 13:28]
Report message to a moderator
Previous Topic:Unrecognized variable: (name) error in Acceleo
Next Topic:Texo support for fluent methods?
Current Time: Tue Jun 15 03:35:36 GMT 2021
Powered by FUDForum. Page generated in 0.01939 seconds
