Home » Newcomers » Newcomers » Which version did I install?(I want to duplicate my installation elsewhere)
Which version did I install? [message #1828981] Tue, 23 June 2020 15:12 Go to next message
Mark Vaughan is currently offline Mark VaughanFriend
I'd like to install Eclipse on a Windows 10 PC in the same configuration as I have installed on a different Windows 10 PC. When I run the Eclipse Installer, it gives me a list of configurations to choose from (the first one is Eclipse IDE for Java Developers). How can I determine which option I chose originally so I can get the same one?
Thanks!
Re: Which version did I install? [message #1828985 is a reply to message #1828981] Tue, 23 June 2020 16:13 Go to previous messageGo to next message
Look at Help -> About Eclipse IDE. This will tell which product and version thereof that you have installed.
Ed Merks
Re: Which version did I install? [message #1828990] Tue, 23 June 2020 17:09 Go to previous messageGo to next message
No Message Body
Re: Which version did I install? [message #1828991 is a reply to message #1828985] Tue, 23 June 2020 17:13 Go to previous messageGo to next message
Ed,
Thanks for your response. It doesn't tell me which option I selected with the installer.
Here's what I see:
Version: 2020-06 (4.16)
Build id: I20200604-0540
Additionally, there are about 100 modules installed when I look at Installation Details, but none tells which option I installed (that I can see).
Re: Which version did I install? [message #1829018 is a reply to message #1828991] Wed, 24 June 2020 04:57 Go to previous messageGo to next message
There's also the name of that product as the first thing in that dialog which is the name of the product. The "Version: "tells you the version.
For more technical (exact) details, you can also use Navigate -> Open Setup -> Installation. A reference to the Oomph Product Version that you selected will appear here in the tree view. E.g., "Latest (2020-09) (Eclipse.org - Eclipse IDE for Eclipse Committers)".
Ed Merks
Re: Which version did I install? [message #1829028 is a reply to message #1828981] Wed, 24 June 2020 07:38 Go to previous message
Tauno Voipio is currently offline Tauno VoipioFriend
You can export the configuration from the reference Eclipse:
File -> Export -> Install -> Installed Software Items to File
It creates a .p2f file which should be copied to the target machine.
In the target machine, install a bare-bones Eclipse (e.g. for Java), open it and import the .p2f:
File -> Import -> Install -> Installed Software Items from File.
Before the operation, please check that the reference Eclipse is up to date, and it is a good idea to let the export wizard check that the modules do exists in repositories.
Tauno Voipio
Previous Topic:License management strategy and eclipse platform support for the same
Next Topic:Keybinding conflicts involving jface plug-in
Current Time: Wed Oct 21 14:16:33 GMT 2020
Powered by FUDForum. Page generated in 0.03244 seconds
