Home » Polarsys » Capella workbench » problem with .aird
problem with .aird [message #1828978] Tue, 23 June 2020 14:48 Go to next message
Julien Morane is currently offline Julien MoraneFriend
Hello everyone,
After I tried to open the PVMT view, Capella crashed and leave me with a problem on one project (image attached).
Below the .aird, , only the folder 'Representation per category' appears...
Has anyone ever faced the same problem ?
Re: problem with .aird [message #1828993 is a reply to message #1828978] Tue, 23 June 2020 17:39 Go to previous messageGo to next message
Stephane LACRAMPE is currently offline Stephane LACRAMPEFriend
Anything in the error log or another .log file?
You may try the "repair" function on your aird file but not sure it will fix your issue...
Stephane LACRAMPE
Obeo Canada
Re: problem with .aird [message #1829067 is a reply to message #1828993] Wed, 24 June 2020 14:23 Go to previous messageGo to next message
Where can you find the .log files ?
The function repair has'nt worked btw.
thanks,
Re: problem with .aird [message #1829072 is a reply to message #1829067] Wed, 24 June 2020 15:58 Go to previous messageGo to next message
Usually, it would be in your workspace folder under the .metadata folder, they should be a .log file. You may also look for *.log file in your workspace or Capella forlder.
Stephane LACRAMPE
Obeo Canada
Re: problem with .aird [message #1829073 is a reply to message #1829072] Wed, 24 June 2020 16:33 Go to previous messageGo to next message
Hello Stéphane,
I watched in the .log files : however, the last error message that is displayed was dated from March....
I am using Capella 1.4.0 btw.
Rgds,
Re: problem with .aird [message #1829074 is a reply to message #1829073] Wed, 24 June 2020 16:36 Go to previous message
ok, I don't know exactly what I can do now, can you send me your project files?
Stephane LACRAMPE
Obeo Canada
Previous Topic:Physical Architeture
Next Topic:Requirement tables in Capella
Current Time: Fri Dec 06 13:22:26 GMT 2024
Powered by FUDForum. Page generated in 0.03520 seconds
