Home » Eclipse Projects » BPMN 2.0 Modeler » Import dataobjects?(Is ist possible to import data objects)
Import dataobjects? [message #1828928] Mon, 22 June 2020 14:48 Go to next message
Simon Hettwer is currently offline Simon HettwerFriend
we try to model some business processes which reference often the same data objects.
Is it possible to define the data objects in a separate bpmn file and import this to our actual process model. There we could only use data object references to those data objects of the dedicated file.
Greetings
Simon
Re: Import dataobjects? [message #1828939 is a reply to message #1828928] Mon, 22 June 2020 16:51 Go to previous messageGo to next message
Ralph Soika is currently offline Ralph SoikaFriend
Hi Simon,
no, this is not possible. The data objects are part of the BPMN spec. But if you have an engine processing your model it may be a solution to only place the file reference into a data object and resolve the content at runtime. For example this will also avoid storing sensible data in a bpmn file.
I hope this helps.
Ralph
Re: Import dataobjects? [message #1828950 is a reply to message #1828939] Tue, 23 June 2020 06:44 Go to previous message
Hi Ralph,
thank you for your quick response. I think we have to live with it for now.
Greetings
Simon
Previous Topic:BPMN 2.0 Modeler for Eclipse 2020-03
Next Topic:triage usage before file a bug
Current Time: Sun Oct 01 16:57:43 GMT 2023
Powered by FUDForum. Page generated in 0.02429 seconds
