Eclipse 2020-06 - Decoration Calculation has encountered a problem [message #1828841] |
Fri, 19 June 2020 17:23 |
Mike Viens Messages: 6 Registered: June 2020 |
I am using a completely new installation of Eclipse 2020-06. I installed the plug-ins for Subclipse, JBoss Tools, and Spring Tools 4.
I created a new directory, checked out the source code, and imported as existing Maven project. I have gotten many errors, with the most common being attributable to:
java.lang.NoSuchMethodError: org.eclipse.core.internal.content.Activator.getFactory()Ljavax/xml/parsers/SAXParserFactory;
I am using JBoss' OpenJDK 1.8.0_252.
With Eclipse 2020-03, I was not seeing these errors. I have attached the Eclipse .log file. I have checked for, and installed, all available Eclipse updates.
Attachment: .log
(Size: 26.35KB, Downloaded 198 times)
Re: Eclipse 2020-06 - Decoration Calculation has encountered a problem [message #1829004 is a reply to message #1828943] |
Tue, 23 June 2020 21:01 |
I pointed to Fuse because your log contained:
at org.fusesource.ide.foundation.core.xml.namespace.FindNamespaceHandlerSupport.parseContents(FindNamespaceHandlerSupport.java:67)
at org.fusesource.ide.foundation.core.xml.namespace.NamespaceXmlContentDescriberSupport.fillContentProperties(NamespaceXmlContentDescriberSupport.java:106)
at org.fusesource.ide.foundation.core.xml.namespace.NamespaceXmlContentDescriberSupport.checkCriteria(NamespaceXmlContentDescriberSupport.java:45)
at org.fusesource.ide.foundation.core.xml.namespace.NamespaceXmlContentDescriberSupport.describe(NamespaceXmlContentDescriberSupport.java:77)
at org.fusesource.ide.foundation.core.xml.namespace.NamespaceXmlContentDescriberSupport.describe(NamespaceXmlContentDescriberSupport.java:64)
...which shows Fuse code accessing a method on a class that is not public API. Internal classes are free to change however they like. It appears properly fixed through FUSETOOLS-3318, the compile-time version of the problem.
_
Nitin Dahyabhai
Eclipse Web Tools Platform
FUDForum. Page generated in 0.09605 seconds
