Error 7009 since Java 11 [message #1828661] |
Tue, 16 June 2020 07:20 |
Niklas Schloegel Messages: 3 Registered: June 2020 |
I used Jubula to test our Java 1.8 Swing/FX-Application before. Now, after switching to Java 11.0.2, tests from Jubula are not running. The AUT starts, gets recognized and is listed under 'Running AUTs', but after starting a Test Suite, I get the following error pop-up:
An error occurred. Reason: 7009: Test Execution Error.
Details: This connection is not connected.
One latest log entry (in rc_swing.log) is following, often repeating Exception:
2020-06-16 08:56:02.503 [Thread-18] ERROR o.e.j.r.s.c.AUTSwingHierarchy - Method called outside of the dispatch thread. This may indicate a potential error in the AUT.
java.lang.Exception: null
at org.eclipse.jubula.rc.swing.components.AUTSwingHierarchy.checkDispatchThread(AUTSwingHierarchy.java:1031) ~[org.eclipse.jubula.rc.swing_7.0.2.201902270829.jar:na]
at org.eclipse.jubula.rc.swing.components.AUTSwingHierarchy.componentAdded(AUTSwingHierarchy.java:426) ~[org.eclipse.jubula.rc.swing_7.0.2.201902270829.jar:na]
at java.desktop/java.awt.AWTEventMulticaster.componentAdded(AWTEventMulticaster.java:208) ~[na:na]
at java.desktop/java.awt.Container.processContainerEvent(Container.java:2289) ~[na:na]
at java.desktop/java.awt.Container.processEvent(Container.java:2260) ~[na:na]
at java.desktop/java.awt.Component.dispatchEventImpl(Component.java:5008) ~[na:na]
at java.desktop/java.awt.Container.dispatchEventImpl(Container.java:2321) ~[na:na]
at java.desktop/java.awt.Component.dispatchEvent(Component.java:4840) ~[na:na]
at java.desktop/java.awt.Container.addImpl(Container.java:1163) ~[na:na]
at java.desktop/java.awt.Container.add(Container.java:436) ~[na:na]
at heissmann.gui.MainFrame.initHauptmenue(MainFrame.java:1229) ~[Heissmann.Gui-3.0.jar:na]
at heissmann.gui.MainFrame.access$100(MainFrame.java:95) ~[Heissmann.Gui-3.0.jar:na]
at heissmann.gui.MainFrame$1$1.run(MainFrame.java:154) ~[Heissmann.Gui-3.0.jar:na]
at java.base/java.lang.Thread.run(Thread.java:834) ~[na:na]
The AUT is started through following batch script:
java --module-path "C:\Program Files\Java\javafx-sdk-11.0.2\lib" --add-modules=javafx.base,javafx.controls,javafx.fxml,javafx.graphics,javafx.media,javafx.swing,javafx.web,javafx.swt -Xmx1028M -Xms128M -jar DataTool.jar --add-opens=javafx.controls/javafx.scene.control.skin=ALL-UNNAMED --illegal-access=permit
FUDForum. Page generated in 0.04745 seconds
