tycho-surefire-plugin failed to open Papyrus diagram [message #1828463] |
Wed, 10 June 2020 09:17 |
Alberto Debiasi Messages: 84 Registered: March 2018 |
Member |
There is a JUnit plug-in test that tries to open a BDD diagram and export it as image file.
If I run the test via Eclipse as "run as JUnit plug-in test" it works.
If I run the test via console using mvn install, the following errors appear:
2020-06-10 10:49:24 ERROR tools:110 - org.eclipse.papyrus.infra.tools - 0 - The class org.eclipse.papyrus.uml.diagram.interactionoverview.edit.advices.CallBehaviorActionAsInteractionEditHelperAdvice doesn't exist
java.lang.ClassNotFoundException: org.eclipse.papyrus.uml.diagram.interactionoverview.edit.advices.CallBehaviorActionAsInteractionEditHelperAdvice cannot be found by org.eclipse.papyrus.infra.tools_2.0.1.201703080851
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:461)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:372)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:364)
at org.eclipse.osgi.internal.loader.ModuleClassLoader.loadClass(ModuleClassLoader.java:161)
at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
at org.eclipse.osgi.internal.framework.EquinoxBundle.loadClass(EquinoxBundle.java:564)
at org.eclipse.papyrus.infra.tools.util.ClassLoaderHelper.loadClass(ClassLoaderHelper.java:53)
at org.eclipse.papyrus.infra.tools.util.ClassLoaderHelper.loadClass(ClassLoaderHelper.java:79)
at org.eclipse.papyrus.infra.tools.util.ClassLoaderHelper.newInstance(ClassLoaderHelper.java:107)
at org.eclipse.papyrus.infra.types.core.factories.impl.DefaultEditHelperAdviceFactory.getEditHelperAdvice(DefaultEditHelperAdviceFactory.java:30)
at org.eclipse.papyrus.infra.types.core.factories.impl.DefaultEditHelperAdviceFactory.getEditHelperAdvice(DefaultEditHelperAdviceFactory.java:1)
at org.eclipse.papyrus.infra.types.core.factories.impl.AbstractAdviceFactory.createEditHelperAdviceDescriptor(AbstractAdviceFactory.java:29)
at org.eclipse.papyrus.infra.types.core.registries.AdviceConfigurationTypeRegistry.getEditHelperAdviceDecriptor(AdviceConfigurationTypeRegistry.java:93)
at org.eclipse.papyrus.infra.types.core.utils.TypesConfigurationsCycleUtil.getDependenciesAmongAdvices(TypesConfigurationsCycleUtil.java:71)
at org.eclipse.papyrus.infra.types.core.registries.ElementTypeSetConfigurationRegistry.loadElementTypeSetConfigurations(ElementTypeSetConfigurationRegistry.java:330)
at org.eclipse.papyrus.infra.types.core.registries.ElementTypeSetConfigurationRegistry.init(ElementTypeSetConfigurationRegistry.java:103)
at org.eclipse.papyrus.infra.types.core.registries.ElementTypeSetConfigurationRegistry.getInstance(ElementTypeSetConfigurationRegistry.java:84)
at org.eclipse.papyrus.infra.types.core.TypesConfigurationsRegistryService.startService(TypesConfigurationsRegistryService.java:36)
at org.eclipse.papyrus.infra.core.services.internal.ServiceEntry.startService(ServiceEntry.java:152)
at org.eclipse.papyrus.infra.core.services.internal.StartStartupEntry.startService(StartStartupEntry.java:81)
at org.eclipse.papyrus.infra.core.services.ServicesRegistry.startServices(ServicesRegistry.java:1020)
at org.eclipse.papyrus.infra.core.services.ServicesRegistry.startRegistry(ServicesRegistry.java:488)
at org.eclipse.papyrus.infra.ui.editor.CoreMultiDiagramEditor.loadModelAndServices(CoreMultiDiagramEditor.java:613)
at org.eclipse.papyrus.infra.ui.editor.CoreMultiDiagramEditor.initContents(CoreMultiDiagramEditor.java:932)
at org.eclipse.papyrus.infra.ui.editor.CoreMultiDiagramEditor.init(CoreMultiDiagramEditor.java:481)
at org.eclipse.ui.internal.EditorReference.initialize(EditorReference.java:362)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:318)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:55)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:966)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:931)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:151)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:375)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:294)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:162)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:105)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:74)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:56)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:129)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:975)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:651)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:757)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$0(PartRenderingEngine.java:728)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$2.run(PartRenderingEngine.java:722)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:706)
at org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1324)
at org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer$1.handleEvent(LazyStackRenderer.java:72)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:40)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:233)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:145)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4821)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:211)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:36)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:201)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:94)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:60)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:173)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.showElementInWindow(ModelServiceImpl.java:617)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.bringToTop(ModelServiceImpl.java:581)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.delegateBringToTop(PartServiceImpl.java:770)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.bringToTop(PartServiceImpl.java:401)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.showPart(PartServiceImpl.java:1214)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:3261)
at org.eclipse.ui.internal.WorkbenchPage.access$25(WorkbenchPage.java:3176)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:3158)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3153)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3117)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:3107)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:563)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:518)
at org.polarsys.chess.contracts.profile.chesscontract.util.EntityUtil.openCurrentModelIntoEditor(EntityUtil.java:249)
at org.polarsys.chess.contracts.verificationService.test.runtime.tests.TestBasicOperations.openEditor(TestBasicOperations.java:269)
at org.polarsys.chess.contracts.verificationService.test.runtime.tests.TestBasicOperations.testGenerationDocumentation(TestBasicOperations.java:208)
at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:50)
at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:12)
at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:47)
at org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:17)
at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:26)
at org.junit.rules.Verifier$1.evaluate(Verifier.java:35)
at org.junit.rules.TestWatcher$1.evaluate(TestWatcher.java:55)
at org.eclipse.papyrus.junit.utils.rules.ProjectFixture$1.evaluate(ProjectFixture.java:162)
at org.junit.rules.RunRules.evaluate(RunRules.java:20)
at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:325)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:78)
at org.eclipse.papyrus.junit.framework.classification.ClassificationRunner.access$0(ClassificationRunner.java:1)
at org.eclipse.papyrus.junit.framework.classification.ClassificationRunner$1.runChild(ClassificationRunner.java:56)
at org.eclipse.papyrus.junit.framework.classification.ClassificationRunnerImpl.runChild(ClassificationRunnerImpl.java:85)
at org.eclipse.papyrus.junit.framework.classification.ClassificationRunner.runChild(ClassificationRunner.java:84)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:57)
at org.junit.runners.ParentRunner$3.run(ParentRunner.java:290)
at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:71)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:288)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java:58)
at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:268)
at org.junit.runners.ParentRunner.run(ParentRunner.java:363)
at org.apache.maven.surefire.junit4.JUnit4Provider.execute(JUnit4Provider.java:264)
at org.apache.maven.surefire.junit4.JUnit4Provider.executeTestSet(JUnit4Provider.java:153)
at org.apache.maven.surefire.junit4.JUnit4Provider.invoke(JUnit4Provider.java:124)
at org.apache.maven.surefire.util.ReflectionUtils.invokeMethodWithArray2(ReflectionUtils.java:208)
at org.apache.maven.surefire.booter.ProviderFactory$ProviderProxy.invoke(ProviderFactory.java:156)
at org.apache.maven.surefire.booter.ProviderFactory.invokeProvider(ProviderFactory.java:82)
at org.eclipse.tycho.surefire.osgibooter.OsgiSurefireBooter.run(OsgiSurefireBooter.java:95)
at org.eclipse.tycho.surefire.osgibooter.AbstractUITestApplication$1.run(AbstractUITestApplication.java:35)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:182)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4211)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3827)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$4.run(PartRenderingEngine.java:1121)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:150)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:693)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:610)
at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:138)
at org.eclipse.tycho.surefire.osgibooter.UITestApplication.runApplication(UITestApplication.java:31)
at org.eclipse.tycho.surefire.osgibooter.AbstractUITestApplication.run(AbstractUITestApplication.java:120)
at org.eclipse.tycho.surefire.osgibooter.UITestApplication.start(UITestApplication.java:37)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:673)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:610)
at org.eclipse.equinox.launcher.Main.run(Main.java:1519)
at org.eclipse.equinox.launcher.Main.main(Main.java:1492)
2020-06-10 10:49:24 ERROR core:110 - org.eclipse.papyrus.infra.core - 0 - Unexpected Error
org.eclipse.papyrus.infra.core.services.ServiceMultiException: Multiple exceptions
----- exceptions : ----------
ElementTypesConfigurationsRegistryService : java.lang.NullPointerException
at org.eclipse.papyrus.infra.core.services.ServicesRegistry.startRegistry(ServicesRegistry.java:456)
The build part of the pom.xml is the following:
<build>
<plugins>
<plugin>
<groupId>org.eclipse.tycho</groupId>
<artifactId>tycho-surefire-plugin</artifactId>
<configuration>
<failIfNoTests>false</failIfNoTests>
<product>org.eclipse.platform.ide</product>
<useUIHarness>true</useUIHarness>
<useUIThread>true</useUIThread>
</configuration>
</plugin>
</plugins>
</build>
Do you have any idea related to this problem?
Thanks in advice,
Alberto
[Updated on: Wed, 10 June 2020 09:17] Report message to a moderator
FUDForum. Page generated in 0.03705 seconds
