Re: Latest download does not contain WTP [message #1828339 is a reply to message #1828313] |
Mon, 08 June 2020 01:33 |
That's mostly correct. The list of feature IDs found on https://www.eclipse.org/downloads/packages/release/2020-03/r/eclipse-ide-web-and-javascript-developers-includes-incubating-components show that package, and corresponding installation option, are built around a different set of tools with a different opinion on how those tools should be integrated.
You can add the Web Developer Tools to your installation from the Help menu, by using its Install New Software action. More guidance can be
found at https://wiki.eclipse.org/WTP_FAQ#How_do_I_install_WTP.3F .
_
Nitin Dahyabhai
Eclipse Web Tools Platform
[Updated on: Mon, 08 June 2020 01:34] Report message to a moderator
Re: Latest download does not contain WTP [message #1833007 is a reply to message #1832538] |
Wed, 30 September 2020 13:51 |
Jim Anderson Messages: 109 Registered: October 2014 |
@Nitin
Thank you for your response. It got me one step closer. The "JST UI" was not installed, so I have installed it.
I still cannot run the the WTP. I was going to close this issue and open a new one to describe my current issue, but I cannot figure out how to close this thread and mark it as resolved, so I will
continue in this thread with my next post.
Jim
[Updated on: Wed, 30 September 2020 14:01] Report message to a moderator
Re: Latest download does not contain WTP [message #1833025 is a reply to message #1833009] |
Thu, 01 October 2020 02:39 |
The Preview server, unfortunately, doesn't support server-side debugging of JSPs, but just to make sure we're on the same page,
are you trying to debug JavaScript on the rendered version of the JSP in a web browser (Firefox), or are you looking to debug the Java
on the server-side as your JSP executes to render page output for the client?
If it's the server-side, case 2 could be what's described in the FAQ.
As for case 1, running and debugging on server are meant to open what you've selected using your Web Browser. Check that preference
page to see if Geany is set there somehow. Unless what's opened actually requests your page, it won't be executed and you won't have any code
executing to debug.
_
Nitin Dahyabhai
[Updated on: Thu, 01 October 2020 02:40] Report message to a moderator
FUDForum. Page generated in 0.04628 seconds
