Home » Eclipse Projects » BIRT » Count rows in Birt(Doubt about comands)
Count rows in Birt [message #1828229] Thu, 04 June 2020 13:34 Go to next message
Isaac Manolo is currently offline Isaac ManoloFriend
Hello everyone,
I have a doubt. I came across the following command line in Birt:
row ['line_1'] + '-' + Datasetrow ['line_2'].
I wonder what that means.
Thanks.
Re: Count rows in Birt [message #1830808 is a reply to message #1828229] Tue, 04 August 2020 13:14 Go to previous messageGo to next message
dmitry khotsko is currently offline dmitry khotskoFriend
Member
I think it's concatenation
Re: Count rows in Birt [message #1831101 is a reply to message #1830808] Tue, 11 August 2020 19:11 Go to previous messageGo to next message
Thomas Gutmann is currently offline Thomas GutmannFriend
Hi Isaac,
yes, dimitry are right, the command is concatenation.
The difference is the way how you access the values of the date set one times with row[] and one times with dataSetRow[].
But with this concatenation you won't count rows at BIRT.
Kind regards
Re: Count rows in Birt [message #1831244 is a reply to message #1828229] Sat, 15 August 2020 00:29 Go to previous message
Thanks guys!!!
Previous Topic:Embedded scripts does not work when Run->View Report->as PDF
Next Topic:Report Layout printout in PDF not same issue
Current Time: Wed Oct 27 19:13:25 GMT 2021
Powered by FUDForum. Page generated in 0.01376 seconds
