OSGI extender error [message #1828226] |
Thu, 04 June 2020 12:03 |
adil mo Messages: 1 Registered: June 2020 |
Hi All,
We are trying to use Gemini blueprint for running spring 5.2.5 on JDK 11.
All three bundles (gemini-core, io and extender) are installed and active. But still we are getting following error while creating context for new bundle,
gemini-io bundle is installed already. I even extracted the bundle and found that the class OsgiBundleResourcePatternResolver is there . Also, the export-package is in place for gemini-io
04.06.2020 06:58:12.916 *ERROR* [FelixDispatchQueue] org.eclipse.gemini.blueprint.extender FrameworkEvent ERROR (java.lang.NoClassDefFoundError: org/eclipse/gemini/blueprint/io/OsgiBundleResourcePatternResolver)
at org.eclipse.gemini.blueprint.context.support.AbstractOsgiBundleApplicationContext.createResourcePatternResolver(AbstractOsgiBundleApplicationContext.java:416)
at org.eclipse.gemini.blueprint.context.support.AbstractOsgiBundleApplicationContext.setBundleContext(AbstractOsgiBundleApplicationContext.java:147)
at org.eclipse.gemini.blueprint.extender.support.DefaultOsgiApplicationContextCreator.createApplicationContext(DefaultOsgiApplicationContextCreator.java:70)
at org.eclipse.gemini.blueprint.extender.internal.activator.LifecycleManager.maybeCreateApplicationContextFor(LifecycleManager.java:166)
at org.eclipse.gemini.blueprint.extender.internal.activator.ContextLoaderListener$ContextBundleListener.handleEvent(ContextLoaderListener.java:86)
at org.eclipse.gemini.blueprint.extender.internal.activator.listeners.BaseListener.bundleChanged(BaseListener.java:87)
at org.apache.felix.framework.EventDispatcher.invokeBundleListenerCallback(EventDispatcher.java:915)
at org.apache.felix.framework.EventDispatcher.fireEventImmediately(EventDispatcher.java:834)
at org.apache.felix.framework.EventDispatcher.fireBundleEvent(EventDispatcher.java:516)
at org.apache.felix.framework.Felix.fireBundleEvent(Felix.java:4817)
at org.apache.felix.framework.Felix.startBundle(Felix.java:2336)
at org.apache.felix.framework.BundleImpl.start(BundleImpl.java:998)
at org.apache.felix.webconsole.internal.core.BaseUpdateInstallHelper.run(BaseUpdateInstallHelper.java:192) [org.apache.felix.webconsole:4.3.8]
at java.base/java.lang.Thread.run(Thread.java:834)
FUDForum. Page generated in 0.01475 seconds
